Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
To make the temp inside the refrigerator colder?
To make the refrigerator colder inside, do I need to put the dial at `1 or 7?
    President:
  • Amana Master
  • 2,651 Answers
7 will be your cldest temp
Posted on Nov 02, 2008
  • clrkbrs Jul 14, 2011
    My husband kept telling me that 1 was the coldest and there must be something wrong with the fridge because nothing would stay cold. I thought the same until I saw that the Off setting was listed after the 1. Then I knew 7 was the coldest setting but thanks for confirming!
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
What temp should my admiral freezer be at it go,s from warmer to colder 1 to 10?
You need to put a freezer thermometer inside the cabinet.
It should be minus 18 Centigrade or 0 degrees Fahrenheit.
Start off at 5 on your dial and adjust daily until you reach -18/0
You can pick these up at Home Depot or Houseware stores.
Fridge Or Freezer Thermometer 52 mm Dial Colour Coded Zones Ideal For Home...
May 13, 2016 | Admiral Refrigerators
What cold setting should my fridge be on?
Put both dials on cold and wait 48 hours then adjust from there.
Aug 27, 2012 | Frigidaire Refrigerators
I dont understand temp dial on LG 232SBF Frost free fridge freezer
Hello there and welcome to fixya
this is actually a simple dial
this is what they mean
C= COLDER THIS IS THE SETTING IF YOU WANT TO LOWER THE TEMPERATURE FROM LETS SAY 38 DEGREES TO 35 DEGREES THEN YOU WOULD TURN THE DIAL A LITTLE BIT TOWARDS THE C
N= NORMAL RANGE THIS IS WHERE IT SHOULD BE SET AT AFTER IT IS AT THE TEMPS ARE ALLOWED TO STABILIZE
W=WARMER MEANING IF THE REFRIGERATOR IS TOO COLD MOVE IT TOWARDS THE W A FEW NOTCHES THIS WILL INCREASE THE TEMP MAKING IT A LITTLE BIT WARMER INSIDE OF THE REFRIGERATOR
OK? HOPE THIS HELPS PLEASE IF THIS HELPS GIVE MEA GOOD RATING I NEED ALL THE HELP I CAN GET
BEST REGARDS MIKE
Dec 21, 2011 | Radio Communications
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
Fridge not keeping cold whats the best temp. we only have no.s 1 to 10.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 1005 reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
1 is the temperature thermostat, it actually controls the compresssor motors cycling,
thus box temperature as well, it often says 1-10 and off as well, the reamining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the refers box!
This is where the problems occur, when one notices the reefers box warm they max both settings,
which seems logical , and is for the thermostat dials setting.
Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!
Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!
not colder reefer! so you max or raise the thermostat, thats ok to do.
But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.
I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.
when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm too much in another day or so. But if the freezers making ice for days and never getting wet theres a airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it icedd up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?
setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons water.
Dec 27, 2010 | GE Profile PSI23NCR Side by Side...
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
With the BevAir DW49 does a lower number mean colder or warmer?
1 is usually the warmest setting. The higher the number to colder the setting. Start in the middle and make minor adjustments allowing considerable time in between to dial in the temp of your unit.
Dec 04, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
2,663 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
