Question about Welding Tools
Need welding manual for Krieger Mars 200 mig/mag
luxur4
  • 92 Answers
SOURCE: Mig Question
MIG welding is the term used for Metal Inert gas, where the gas is Argon and used for Aluminium Welding, The gas has no effect on the arc apart from shieling the weld bead for outside atmosphere, MAG welding is Metal Active gas where to gas does have an effect on the arc and is common with welding mild steel etc. the gas is argon with an acitive gas such as CO2 or Oxygen in different amounts. A contiuous wire feed system fed from a 1lb reel or a 15 kl reel of wire.of 0.8mm upto 1.6mm dia wires the larger 400amp can feed cored wires giving very high metal transfer.
Posted on Jan 24, 2009
  • 14 Answers
SOURCE: what setting do I need to weld aluminum for a 135 miller mig weld
start slowly turning up the wire feeder,and the amps till you get the sound of bacon crackeling and youll know your there. hope this helps jojogunne
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 6 Answers
SOURCE: i need an owners manual for my clark weld mig
Hi, You can also go to clarke power products and get the manuals , I did for my 180 the site is still up and running for information on the welders
Posted on Oct 24, 2009
  • 81 Answers
SOURCE: Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Posted on Apr 21, 2010
Who makes the pro x one mig 200?
seems to be Lincoln Electric from my searching. Plus mentioned in this old Fixya post.
http://www.fixya.com/support/t12183547-proxone_mig_welders_manuals
pro one mig 200 Google Search
Apr 06, 2017 | Welding Tools
I have just bought a Gasless Mig Welder and someone has said its only used for tacking. Is this right?
wrong
gasless mig welders are used the same as gas /wire migs
the only difference is the polarity of the leads to the hand piece and the work ground and this is indicated by the plug in the machine for the ground lead
what the "someone " would have been referring to is the duty cycle of the unit
every welder has a duty cycle because of the heat generated in the welding process by the electronic components and transformers and if that duty cycle is exceeded the machine stops working until it cools down or damages the circuits
it is stated as a % of time in use so a unit with a 20% duty cycle means that for every 20% of use it has to cool for 80% of time
as an example ---if you were using a stick welder, the time taken to burn the stick would be 20% and the time taken to insert a new stick and clean the slag off the weld to resume the process would be the 80%
It also depends on the amps being used for the weld
on a machine with 120amps capacity and you were using 15 amps to weld sheet metal--body panels - the length of welding time will be considerable compared to using 115 amps where the weld time would be a few minutes
there are plenty of helpful hints in the operators manual and other technical publications on line
Aug 09, 2016 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
This is a new 135g I bought on ebay the wire feeder worked one time now it will do nothing the shaft will not move
I would suggest you go to a welding supply,
not mention ebay,and get it fixed correctly
and have them explain how to set it up etc
Feb 05, 2011 | V, Inc. 135g Mig Mag Welder Machine Gas ...
I need an information about the problems of Kemppi MIG/Mag Pro 500 most common problems and way to fix it.I have to create a maintenance record about this machine and i dont how to get an information about...
Go to kemppi.com once there go to the sub menu click on support then click on "disturbances in MIG/MAG welding" or just check the owners manual.
Feb 02, 2011 | Welding Tools
The fan of the machine works and looks ok but the motor doesen't run.
Unplug you welding gun and try to bridge the connector, if the motor turns, then you have a faulty trigger, if not your PC board needs to be replace.
Jan 05, 2011 | V, Inc. 135g Mig Mag Welder Machine Gas ...
Wiring diagrams for lincoln sa-200 F-163 welding machine
try Westermans - used welding machines supplier. They stock the best brands like Lincoln, ESAB, Kemppi and Fronius. They should also have operator manuals for most machines. email them at welding@westermans.com ask for Craig.
Sep 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
186 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
