Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Need transistor need to find a transistor for my SS board, part # 2PG001. can someone help please. laz
  • Anonymous Mar 23, 2009
    can you please tell me were I can get this transistor from thanks.
  • Abimael Reyes
    Abimael Reyes Mar 23, 2009
    Can you please tell me were I can get this transistor from.
    The TV is Panasonic TH-42PD60U and the part is the transistor #2PG001. Thanks.
    Problem Solver:
Finally I have managed to fix my plasma 6842PEM. My problem was the SS (Sustain) Board and not the Power supply. This board is the vertical one to the right connecting to the Screen/Panel. I tested every component on the board and found one of the Transistors on the heat sink was bad, part # 2PG001. This board is made by Panasonic which can be replaced. I got the Transistor which only cost $20.00 including shipping.
To identify wether this is your problem, disconnect the cable comming from the power board and put on the TV, If the green light stays on then this is your problem.
Thanks all for your help.
Laz
Posted on Nov 24, 2008
  • Wmichael12 Jan 08, 2012
    I have found the same problem with my tv. Even the same part number on the bad transistor. The current problem that I have is that I can't find a replacement part. I looked online and have made many calls. Could someone please share where I would find this part? My cell is 928-308-2261 text or call please thanks
What is the equivalent or alternative numbers for 2PG001
come on John
be fair if you want an answer
what the hell is a 2pg001,
where does it fit ,
make and model and year
what type of equipment
post again with all if the details as posts are not linked
Apr 01, 2017 | Cars & Trucks
Panasonic TN-42pd60u keeps blowing SS Boards
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 01, 2015 | Panasonic Televison & Video
Laz Boy 6 wires pull out of Okin hand control part # 75000208-01 and would like a wiring diagram to put them back on circuit board.
I had the same problem occur on my la z boy chair. did you ever get an answer to which way to plug the wires back in??Thank you
Apr 20, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
Need solution for Panasonic Plasma TV TC-50PX14 with 6 blink (7 blink when unplug both SF11 and SC2)
Your TV 7 blinks indicates you have a faulty ss board its bad or needs service SS Board (SS Data Energy recovery and data driver). So check ss board for faulty components.
i think it helps
Thank you for using fixya
Chandrashekhar Bhat
Dec 27, 2010 | Panasonic Televison & Video
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic TH-42PX60U Television
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
It keeps blowing fuses, so I checked out the circuit board and it turns out 2 transistors next to each other are blown as they are reading 0 resistance on the multimeter. Can someone help me find a...
Hello there:
if you go to radio shack they have all of these transistors that you will need. these are not hard to replace if you know how to use a soldering iron ok?
best regards mike
Aug 04, 2009 | Earthquake Sound PH800W.2 Car Audio...
Tv wont turn on
hello, usually if your panny is blinking it means theres trouble with your power supply but depending on the number of blinks cuased by a fualty or shorted internal board and this will cuase your tv to go into shutdown mode, it depends on your model number and year it was made.
your best bet is to have a qualified service tech give you a estimate for the repair needed. as long as your screen is okay it will be easy for the service tech to locate and fix your trouble
panasonic blinking codes can pin point the troubled internal part, these blinking fualts are cuase by internal boards with malfunctioning circuts info below for 10th gen 2007 2008 plasma model service
12 Blinks SOS:
On the A board, transistor Q2301 monitors the Sound 15V line and the operation of the audio power amplifier IC2301. If the audio output circuit, IC2301, or the 15V lines develops a short to ground, transistor Q2301 goes into conduction and applies a high to pin 118 of the MPU, IC1100, triggering a SOS condition. The power LED blinks 12 times.
12 Blinks SOS: We have also discovered that 12 blinks of the power LED may also be caused by a defective SS board. To determine the source of the shutdown, disconnect the connector D5 and connect the unit to the AC source. If the panel turns on and the LEDs of the SS and SC boards stay on, the problem is on the A board. If the panel does not stay on, the problem is likely to be the SS board.
hope this helps
Dec 09, 2008 | Panasonic Televison & Video
Repairing Circuit Board
Q553 is a mosfet transistor NTE2973 ,caps1200pf 2k volts c552 is probly good, you might also have to replace STK-392-110s if so you will have to do complete convergence alinement. you need someone who knows how to solder,and do set up alinement for this does have to be done by someone who knows how if not done correctly you can shut set down,then you will really have trouble!!!!!!
Nov 23, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
325 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
