When I start Modern Warfare 3 a error comes up saying this ,'The procedure entry point _BinkSetMixBinVolumes@20 could not be located in the dynamic link library bink32.dll.
SOURCE: fmodex.dll the entry point could not be located in the dynamic link library folder
Method 1:
I would suggest you to uninstall the audio drivers and re-install once again.
To uninstall audio drivers from the device manager follow these steps:
a. Click on Start.
b. Type "Device Manager" in the search bar.
c. Click on Device Manager.
d. Select the device you wish to uninstall in the Device Manager window and uninstall it.
e. You can also uninstall by right clicking on the device and selecting
Uninstall from the context menu. A dialog box will open asking you if you really wish to uninstall the driver. Click
Yes, then OK in the next window.
Install the audio drivers from the manufacturer's website.
Method 2:
Try to re-install the game in cleanboot mode and check if it works.
http://support.microsoft.com/kb/929135
Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow the step 7 in the above article.
If the issue still persists, then contact the manufacturer of the game.
Good Luck!
SOURCE: How do I solve the
Any .dll database/archive site should have MFC30.dll. I personally use http://www.dlldump.com. You'll have to download it, unzip it, and place it into C:\Windows\System32, which should solve your problem.
SOURCE: Error messege on startup
Read the information at the following URL:
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
If this just recently happened (usually due to software install), try running a System Restore back to before you started having the problem.
Go to Start > Programs > Accessories > System Tools and click on System restore.
Follow the prompts and select a bold date back before the problem occurred. You will be prompted to reboot.
If you still have the problem after rebooting, you can try to fix corrupted Windows file by running SFC /scannow from a command prompt (you will likely need your Window XP CD).
If all that fails, boot to your Window XP CD and run a repair. You should not lose any data, but backing up is always recommended..
Let me know if you have questions.
Honest1abe
SOURCE: The procedure entry point SMapLS_IP_EBP_12could
hi,
try to reinstall the IE because once that error occurs, it indicates that your IE is corrupted due to some improper installation or uninstallation of some programs or devices.
hope this helps, good luck, Godbless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
SOURCE: Error message: procedure entry point PowerReadACValue could not
tvagente.exe
is used to use computer as a TV. If you do not use it, you may want
disable it. It uses excessive system and memory resources If you are
not using the TV application, you should remove it to improve your
overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
