Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch model number shu9915uc dishwasher
The water wont drain, or rinse, we checked the hose for kinks or clogs
  • Blair T Nov 22, 2008
    The water seems to spray around during the cycle but at the end there is an inch of water in the bottom of the dish washer. If we run it again, sometimes the water is gone other times not.
  • East63 Dec 26, 2008
    My dishwasher won't drain and I have check the tube and the drain for debris and have not found anything.
    Sergeant:
    Champion:
  • 324 Answers
Check to make sure your float is not jammed in the up position.check for voltage at the fill valve.
Posted on Nov 11, 2008
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | Dishwashers
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Water wont drain out
1)A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem
2)If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
3)Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains, then it is time to call a professional repairman.
Thank you !!
May 25, 2010 | General Electric WSSH300G Front Load...
GE top load washer will not advance to drain and spin
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
Have the Indesit Moon washing machine and it will not finnish the wash cycle and go into spin mode. Is there anything I can do? Thanks
Please donot forget to rate and accept my answer...
Apr 14, 2010 | Indesit W 123 Front Load Washer
Washing cylce completed but is not draining to begin the spinning cyle.
Apr 14, 2010 | Fisher and Paykel Washing Machines
My washing machine will wash but when it comes to rinse & spin it wont & wont drain to can u help thank you ?
  1. 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Apr 10, 2010 | Tecnik TKL9260 Front Load Washer
Water not draining during spin cycle - softener not dispensing into rinse cycle
Just make out the following checks before calling a repairman.
Aug 30, 2009 | Amana Washing Machines
I have a hmwm 6000 washing machine and i suspect the pump is blocked as it won't drain water. How do I get to the pump to unblock it?
Aug 30, 2009 | Washing Machines
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
218 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
