Question about Sony Ericsson HBHPV708 708 Bluetooth Headset Dark
How to reset sony erricson bluetooth headset HBH-PV708
The headset is not being detected on any bluetooth enabled phone.
SOURCE: HOW DO I TURN ON MY SONY ERICSSON HBH PV700 BLUETOOTH?
Figured out the problem, If you hold the Volume + and - buttons for 5+ seconds, The blue tooth will go into Search mode and flash green and red, This will allow you to connect it to new devices, If it was already connected to a previous device everytime you turn it on its searching for the older device, You have to pair it with the newer device
Posted on May 08, 2008
fossildude
  • 832 Answers
SOURCE: how do i connect my HBH-600 bluetooth headset to
hi thanks for using fixya!
Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
Hope it will help you. If you need further assistance, let me know!
Regards!
Posted on Apr 30, 2009
award462
  • 395 Answers
SOURCE: n97 connectivity problem with bluetooth HBH DS 200
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
Posted on Jun 07, 2010
einstein1
  • 194 Answers
SOURCE: My Sony Ericsson Bluetooth headset
www.sonyericsson.com/.../HBH_PV703__UG_R2a_EN_DE_ES_FR.pdf
Posted on Mar 21, 2011
I have sony erricson ds220 bluetooth headset. It was paired to Nokia E5 phone and it was working fine. I lost E5 phone and have bought a new LG phone and headset is not able to connect (discover when i...
Phone: Turn on Bluetooth and Bluetooth visibility. Keep it close to the headset (20 cm).2. Headset: Switch it off. Press and hold down the on/off key until the pairing icon appears on the display.3. Phone: If your phone supports auto pairing, press YES when Add device? appears to complete the procedure. If not, continue with the next step.4. Phone: Follow the applicable User guide to pair with a Bluetooth headset. You may need to enter a headset passcode (0000).
Oct 25, 2017 | Sony Ericsson HBH-DS220 Wireless Headset
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
Pair my Sony Ericsson bluetooth HBH-PV703 with Pantech Impact cell phone
You must put your headset in pairing mode first. Starting with it turned off, press and hold the call handling key until the indicator light flashes alternately in red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the headset should enter the stand-by mode, and there should be some indications on your phone too.
The pairing process between any two bluetooth enabled devices should be done only once. All subsequent connections should be achieved by turning both your headset and your phone's bluetooth radio on and bringing them both into each other's range. At most, a single press on the headset's call handling key should do.
Hope it works for you.
By the way, if your headset's user guide seems to be missing, feel free to download it from this location.
Please, let me know if you need further informations.
Regards, Carlos
Sep 25, 2010 | Sony Ericsson Genuine Bluetooth Headset...
Dec 30, 2009 | Sony Ericsson HBH-PV702 Wireless Headset
N97 connectivity problem with bluetooth HBH DS 200
Sep 08, 2009 | Sony Ericsson HBH-DS200 Stereo Bluetooth...
Can't connect with my n97 (or other Nokia phones). The phone doesn't detect the HBH-IV835.
Read the manual of the HBH-IV835.
Page 15 "Prepare the headset".
This solved the problem!
Aug 25, 2009 | Sony Ericsson HBH-IV835 Bluetooth Headset...
I need ur help
This may help;
Sony Ericsson HBH PV703 bluetooth headset
The cheesy music is nothing to do with me.
Feb 24, 2018 | Sony Ericsson Universal Bluetooth...
Mar 31, 2008 | Sony Ericsson Genuine Bluetooth Headset...
P990i is not supporting headset bluetooth HBH-PV700
You must operate your bluetooth headset HBH-PV700 in discovery mode in order for your mobile to discover the headset and then pair the two devices. To activate the discovery mode of your headset, while it is switched OFF press the switch on button and leave it pressed for approximately 10 seconds, then search for it with your mobile and pair the devices. most of the times the code needed for pairing is 0000 (zeros)
Oct 03, 2007 | Sony Ericsson P990i Smartphone
Pairing
1) Make sure headset is off. 2) Press and hold the answer button until the light flashes green and red. 3) If it only flashes green, press and hold both volume buttons until the light lashes red and green. 4) It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000. 5) All done.
Feb 24, 2007 | Sony Ericsson Universal Bluetooth...
Sony Ericsson HBHPV708 708 Bluetooth Headset Dark Logo
834 people viewed this question
Top Sony Ericsson Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
sandrasteven
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
