Question about Refrigerators
I have a frigidare #PLKU1267DSO kegbox. the compressor runs and gets hot but the box will not cet cold at all. the coils inside also have rust on them
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
Your keg box runs very similar to a Wine Cooler. I believe this can help you. The pressure for the freon and the steps for trouble shooting is he same. Give it a try.
Danby Wine Cooler Repair Recharging your wine Cooler with 134a Freon
Posted on Jun 04, 2015
SOURCE: Kenmore 106.52274202 not cooling
Fridgetech - Help!! I have a very similar problem. Our 1999 Amana BB20/ BRS20 PN 10994558 top frig lower freezer is also warm as of this morning. Fan is working but no cooling. Do you think it is relay or is compressor shot? Ideas?
Thanks!!
Posted on Dec 08, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Posted on Sep 27, 2008
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
  • 14 Answers
SOURCE: Fridge not blowing cold, Buzzing inside black ball "compressor"
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
Posted on May 18, 2009
Frigidare chest freezer model cf-8h-L compressor is running but not getting cold on the inside
Recycle it. It is on R12 which we haven't used for 20 years. If the compressor has gone, or if you have lost all the gas, it is beyond economic repair.
Jul 13, 2015 | Freezers
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
A/C blowing hot air 2000 CDX Daewoo
over filling it was a big mistake, so was guessing.
the freon is added by weight, from empty. not volume.
if the compressor spins, and no cold air , then its a big problem
the only tiny problem to cause this would be leaves packed in evaporator coil. (deep inside air box in cab)
take it to a shop before you damage the compression and fill the whole
thing full of metal chucks wrecking everything, at once $$$$
do not let the compressor run, if it dont get cold. do not.
get it serviced.
Apr 12, 2013 | Suzuki Forenza Cars & Trucks
Unit not getting cold and freezer not cold. compressor is hot to the touch as well. I cleaned the condensor coils and still not getting cold
if the compressor is running and it's not cooling it sounds like you have a leak in the sealed system.you can remove the inside back wall of the freezer and look at the evap coil.if there's ice just on top or ice pattern isn't covering the whole coil then you have a freeon leak in the sealed system.if the compressor is hot it sounds like it's running,i did find the compressor hot,changed out the start device and it did run again but the compressor was clicking,if you're positive the compressor is running most likely you have a leak in the system and it would be to much to fix.part number for the start device is 8201786 and it's around 55 dollars.
Jan 22, 2011 | Whirlpool ED5VHGXM Side by Side...
I have a kitchen aid superba ksrg22fkss15 side by side fridge. Last night the freezer stopped working and I am still trying to determine if the fridge side is working. I pulled off the front and back and...
Can you hear if the compressor is running? The high pressure side of the compressor should be too hot to touch, over 140 F. I assume you mean the condenser fan motor at the bottom of the unit. Try to feel how cold the evaporator coil inside the refrigerator box is. A small capillary tube enters one end of the evaporator. That is the coldest spot. It should still feel at least 35 degrees or colder at the other end of the evaporator where the larger suction line is located. The whole evaporator should be cold. A small portion or none of the evaporator is cold means it is not working. The freezer evaporator should be near -30 F.
Oct 11, 2017 | Refrigerators
Hello I have a frigidare refrigerator Model #GLRS64ZEB7 that doesn't get cold. I cleaned the condensing coiled. I tried it and it still didn't work??? The compressor is running the suction line is getting...
Unit is low on freon......
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 14, 2010 | Frigidaire FFHS2311L Side by Side...
Not getting cold
you need to replace the ptc overload relay located on the compressors body,it isnt actually running right,and the compressor will be quite hot,do this soon otherwise the compressor windings will overheat and destroy the compressor
Mar 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Emerson Compact Refrigerator not cold.
Make sure the condenser fan is running, it is located near the compressor and blows across the condensing coils, and make sure the coils are clean. Compressors usually do get pretty hot though. And make sure all you fans are running in the inside
Aug 21, 2009 | Emerson Refrigerators
Contents does not turn cold
The contents does not get cold even when the fridge runs in my Frigidaire FRTS5A
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 09, 2008 | Frigidaire FRT18FS5A
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
