Question about Sport & Outdoor - Others
I have a York xc530 Elliptical trainer but the monitor has stopped working properly. I have replace the batteries and it allows me to put all the settings in but then will not scan or count down once I start exercising. Very frustrating.
SOURCE: I'm looking for a York xc530 instruction manual.
download it from the York website
http://www.yorkfitness.com/store/IIT_Instructions.asp
You want this one:
http://www.yorkfitness.com/store/PDF/x_xc530_instr.pdf
Posted on Jan 05, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the instruction booklet
That is going to be virtually impossible to obtain online, you will need to contact Confidence to obtain this manual. I believe their number is 1-800-887-7161
Posted on Oct 01, 2010
roadtech7
  • 297 Answers
SOURCE: i need an owner/repair manual
You can log onto www.iconservice.com for a pdf version of your manual for free.
Hope this helps
Posted on Jan 02, 2011
pctech1
  • 1940 Answers
SOURCE: My star trac Polar elliptical
  1. Since the device is self-powered, begin striding to charge the device first, and then attempt to turn the device on. The display is powered automatically while striding. If you have an external battery pack connected, it may need to be charged or may have become damaged.
  2. Check the cables at the neck assembly to ensure they are properly connected and not damaged. Unplug and plug them back in to the board. They are located under the MCB Cover:
If the cables are connected correctly, you may have a faulty electronic control board, faulty charging circuit, etc.
I recommend contacting Star Trac customer support here: 1-800-503-1221
They will be able to provide replacement parts, if needed, for your Star Trac Trainer.
Posted on Mar 19, 2011
  • 3 Answers
SOURCE: the program monitor on my eclipse 1100hr/a
Check it out. If you machine monitor shows and e-1 when trying to turn on. Take out the batteries and unscrew the four screws on the bottom of the monitor unplug it from the elliptical. Put the batteries back in turn on monitor the plug it back to the elliptical while still on and screw back in places. It worked for me hope it works for you too.
Brian Pickens
Long beach ca
Posted on May 04, 2011
I fried the labelled R12 resistor beyond identification on the console circuit board of my York 360 HRC elliptical cross trainer. York service is no help. Need schematics on the circuit board or something...
you should be able to get a new R12 resistor at radio shack. be VERY careful when heating the solder up to remove/replace the resistor. Hope this helps!
Nov 16, 2013 | Exercise & Fitness
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
I know that elliptical trainers are a good cardio workout but do they allow you to work your upper body?
Most elliptical trainers nowadays come with moveable arm handles. This gives you more upper body endurance and allows you to burn more calories.
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
I have an efx 546i and when I try to use the incline the panel states: No ramp, low battery
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Jan 03, 2010 | Precor EFX 546i Elliptical Version 4
The ramp will not go up or down. It's states low battery (546i precor)
Dec 29, 2009 | Precor EFX 546i Elliptical Version 4
Find repair service for schwinn treadmill
short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Feb 03, 2009 | Schwinn 430 Elliptical Trainer
Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Sport & Outdoor - Others Logo
144 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
