Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi 62525 DLP TV - No picture. display = Jumping setup screens
I have a 2004 wd 62525 and having problems with the picture. No picture, just tons of flickering and a black screen with a little green tinge. Flasing code 12, which means all okay except check power supply. I have pulled out the PWB and identified 2- 3300 microfarad (10 Vt) caps that are bulging. While I am in here I am wondering if I shoud pick up the kits for the PCB and PWB to fix it. Anyone have any ideas what I should do?
I hate this TV but am saving a few bucks trying to fix it myself.
Please email me at jetmizer@comcast.net. Here is the link to the kits I am looking at. I am not sure whether to get the PCB or PWB kits or maybe just buy the bulging caps as the 1000 micrifarad caps are not visibly bulging....Help.........
http://servicemanuals.vstore.ca/index.php/cName/repair-kits
  • 3 more comments
  • jetmizer Oct 27, 2008
    Guess I'm a little confused with using only the PCB repair kit as the visible problem {bulging caps on the PWB)wouldn't be remedied.
    Are these caps vital to the power supply?
    Can anyone please elaborate as I would rather put more parts in as there was so much time to dig in this far. Based on the problems does this seem symptomatic of the pcb or pwb?
    I will have not problem replacing the individial capacitors on the PWB. AS these are not the typical problem that has been seen on this model, I am wondering based on the symptoms if there are other things I should investigate or replace???
    Thanks very much for your assistance
  • jetmizer Nov 07, 2008
    I have a question about the capacitors I am about to replace. Here are the specs of the original:
    3300 micro farad, 10 vt nichcon with a HD(M) on the side. The replacements I ordered are 33000 micro-farad 63 vt SAMXON with a KM(M) on the side. My question is will this replacement work and what do the Letters HD(M) and KM(M) mean?
    ARe these suitable replacemtents?
    Thanks,
    -Bill
    The 63 volt capacitors will physically fit. DO you think they are okay to use?
  • 2,326 Answers
If the capacitors are bulging, it means they have lost capacitance(value) and that will be affecting the 3.3 volts line. This voltage is powering up part of the microprocessor and memory circuitry and once that voltage is affected it will also affect the video circuitry. Measure the 3.3 volts and you might see that is lower then 3 volts due to the failing capacitors.
I would suggest to replace them as mentioned by bestdarngood and hopefully that should fix the error 12.
Good Luck.
Posted on Oct 27, 2008
  • Jaime Hernandez Nov 07, 2008
    The capacitance should always be as specified by the manufacturers but the voltage can be a bit higher as long it fits in the spacing provided.
    The letters are some kind of code that the manufacturers use to be able to identify the lot, manufacturing date code.
    The 63 volts might be a bit too big for your application due to the size of the part.
    Let me know if you required further assistance.
    They are OK to use as long they are 3300uF.
  • 3,037 Answers
If you are able to replace the individual capacitors yourself, then that would be the cheapest route. If you don't have the knowledge of replacing them, then the easier method (not cheaper) would be to replace the board. I would go the cheapest route that you can accomplish. So if you don't know how to replace the capacitors, then but a full component that doesn't require as much skill to replace.
you could pick up the new caps at any electronics store such as Radio Shack which would be pretty cheap
  • Benjamin Patri
    Benjamin Patri Oct 27, 2008
    well, for now I would replace the bulging caps and then if it happens again, investigate further, I would be more than happy to give further advice once you replace the caps, Depending on how much you use this tv, it may just be time for the caps to be replaced. You may up ending to replace the entire power supply if it happens again in the near future but for now the caps should just be replaced
  • Benjamin Patri
    no problem, please come back if you need any further help
    Genius:
  • 1,550 Answers
You should use PCB kit to fix the problem .
Mitsubishi 62" DLP WD-62525 has no picture no menu only green vertical bars
can you see any of the on screen displays like menu or volume?
I've seen a problem with this model that only had white vertical bars and had to replace the light engine.
Mar 14, 2014 | Mitsubishi Televison & Video
60 inch dlp tv picture is bright mitsubishi
try to restore factory settings so that we can easily diagnose if the problem is on the settings or have a faulty parts inside
Best regards,
Chester
Jan 16, 2012 | Mitsubishi WD-62525 62" Rear Projection...
KEEPS SHUTTING OFF
What type or TV is it DLP , LCD, Plasma?
DLP -----> LAMP--------->go to this 2 sites
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-62525%2062
http://www.discounttvlamps.com/mitsubishi-tv-lamps-s/20.htm
PLASMA------->Digital boar or On switch it depends ... can you go on the Display Menu and it looks goo?
do you see any spots?
LCD-------------> You need DMD Bord
good luck tell me more so we can figure it out!
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Jul 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
