Question about Legacy Home
How to fix a pressure relief device on a dolphin legacy shower
Prd has blown
    New Friend:
Go to dolphin showers website and book a qualified electrician . Do not take chances with amateur electricians from the local paper , or play pin the tail on the donkey with the internet companies who are hundreds of miles away from you . Go to www.dolphin-showers.co.uk and book your approved dolphin repairer.
Posted on Jul 28, 2015
2 Suggested Answers
SOURCE: Water coming from around the bottom of
Piece of P: youre prob right and its the pressure relief device, which is a silicone rubber ball that gets blown out of a branch of the exit pipe just behind where the hose screws on. If you are careful you can push it back with a small (non sharp) screwdriver etc, looking up from underneath. It would be easier to see if you unscrew the hose first.
Posted on Oct 29, 2010
Leak from the bottom of the shower unit
Use ptfe tape or some other kind sealent
Aug 22, 2017 | Water Heaters
Leaking pressure valve when showering or running dishwasher
That happens sometimes when the pressure relief valve goes bad...
Change the relief valve and you'll be good again...
heatman101
Feb 01, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water coming from around the bottom of gainsborough 9.5E electric shower. I think its a pressure release device. Do I need a call out or a new shower. Or can I fix it.
Sep 05, 2010 | Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
Water heater is building pressure in the boiler
Hi, W/D here.
The pressure should be relieved by your PRD (pressure relief device) located on the side of your water heater near the top. It's main purpose is to prevent a water heater explosion.
An inoperable PRD is not a job I'd put off for even one second. If I couldn't work the job right now, at the very lease I'd get the heat off of it, and vent the pressure off at a faucet.
What's important to remember about these devices is that they are for pressure and thermal relief. If there is any doubt that either function is compromised, it should be replaced. Isolate the heat source to the water heater (electricity or gas), vent the hot water at a bathtub, isolate the water inlet connection Drain the heater, taking an air bleed (vent) at one of your hot water faucets. You don't have to drain it completely, just make sure that the water level is below the PRD and that the boiler is isolated and vented as described.
In some cases, minor plumbing modifications are required to get the PRD discharge to the outside or the pan.
If you have any doubts about your ability to perform this job safely, you should call a plumber.
Work carefully and safely. --W/D--
Aug 06, 2009 | Amtrol Water Heaters
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Oct 25, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Home Logo
335 people viewed this question
Top Legacy Home Experts
john h
Tom Chichester
Are you a Legacy Home Expert? Answer questions, earn points and help others
