Question about Acer Computers & Internet
My note book can't read the cd drive - Acer Computers & Internet
    Sergeant:
  • 264 Answers
This issue would be resolved with a simple step which i have provided below.
Click Start, click Run, type regedit and then click OK. Registry Editor starts.
In Registry Editor, expand My Computer, and then expand and open
HKEY_LOCAL_MACHINE>SYSTEM>CurrentControlSet>Control>Class
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane (topic area), right click UpperFilter and delete the entry, also right click Lower Filter and delete the entry.
Close the Registry Editor and Restart the computer.
I am sure that this will work for you.
Please do rate the solution.
All The Best
Sammy
Posted on Oct 27, 2008
I want to reformat my note book...but i don't know how to start it...
Just find a fresh copy of windows in acd. Now put it into the cd drive. Restart your laptop. When the laptop is restarted it will read the cd and will prompt you to "press any key to boot from cd.....". Just press any of the key from keyboard and wait . Now follow the instructions on your screen . When it restarts DO NOT PRESS ANY KEY or booting process will restart again. Just wait and watch . formatting will be completed .
Apr 08, 2011 | Lenovo 3000 Y410 Notebook
My note book does not have cd drive how do i install asus usb n10
you can setup file sharing on a different pc that has a cd drive and run the cd from that pc to your notebook.
Dec 20, 2010 | ASUS Eee 4G Notebook
My note book starts but then shows blank screen and no button functions
Put a bootable CD into the drive and change the boot order in setup to try to boot from the CD first. If it boots, then you know the problem is with the hard drive or with the operating system on the hard drive. Take the hard drive out and slave it to a working computer. Make sure it is the same operating system. You can get an adapter for the cable connection from your local computer store for about $15.00. If you can read the drive on the other computer, then you know the problem is the operating system. Burn all your files to CD or DVD while you have it slaved to the other computer then put the hard drive back into your laptop and then run your recovery discs. After you reinstall the operating system you can reload all your files. If you cannot read the drive when you have it slaved to the other computer, then the drive is toast and needs to be replaced. I hope you have backed up your files regularly.
Nov 18, 2010 | Acer Aspire One PC Notebook
My note book cd rom fail to read and reject all types of cd or dvd. Tell me why, please.
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive.
Aug 15, 2010 | Computers & Internet
My note book compaq presario modelno. c700tu is not giving soun
http://welcome.hp.com/country/us/en/support_task.html
go to site and enter model number and u will find everything releted to your notebook
Jun 24, 2010 | Compaq Presario 700 Series: 1170B01...
Samsung notebook states cannot start as windows file missing and to use disc to repair, however as it is a note book there is no disc drive or disc.
You need a repair/reset CD, and you may need an USB external drive to read it if yours doesn't work or isn't available. The CD may be obtained by Samsung tech support. For Windows XP and Vista you just select OS installation and hit 'R' for repair.
Alternatively you can note down the name of the missing file, locate and save it on a USB key from a computer with the same OS version, and boot the PC using Universal Boot CD (UBCD). Then just copy the file where it should be. Unless you're short a specific driver or VXD, most other files are drop-in compatible.
May 31, 2010 | Samsung X05 Notebook
Hi, My Optiarc DVD RW AD 7530B doesnt read or play DVDS or CDs. it has power but when you click on E drive, an error comes up, that there is no disc
hey gues... we have some problem about my dvd/cd rewritable Drives model AD-7530B . it's my note book HP 520 can detect disk drive , but can not work anything . could you help me and give me information . how i can solution this problem ?... thank's
Jan 26, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Unable to format, partition,ins. os and boot my toshiba TE2100..
The CMOS needs to be set to first read the CD or DVD drive before it reads the Hard drive. Once your XP disk is in the drive it will boot from the CD drive and setup the computer, The CMOS is acessed by turning on the computer and immediatly pressing either the deleat key or the F! or F2 key try each one till you get to CMOS then look for boot section. Set CD drive to first your HD drive to second.
Nov 09, 2009 | Toshiba TE2100 Notebook
Cd is not being read by my laptop so i have no idea how to get started
Hi. Try using an external CD/DVD drive instead. Either your CD or CD drive is corrupted.
Aug 25, 2009 | Western Digital My Book Office Edition 1TB...
Compaq presario 1200-118xl note book problem
Anyone find the answer to this problem yet? I'm having the same problem too..
Feb 06, 2008 | Compaq Presario 1200T and 12XL Series...
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
