Question about Star Logic 17" LCD Monitor
Top Half of monitor is brighter than the bottom half
Hi, I have a StarLogic model MJ7BBA, the top half of the screen is very bright and the bottom half is dark. It is still functional though. Any ideas or advice?
Please refer to the picture I've posted.
Thank you
  • 558 Answers
I think you have a faulty lamp on the bottom, has the unit been serviced at any time? if so then return it and let them reconnect the one lamp they missed, if not then you might have one bad lamp on the bottom of the lcd these typically have 2 lamps on top and two on the bottom, if that is not the case then you might neeed to tilt the screen a little differently,
est I can do for you based on the image you posted. happy holidays
Posted on Dec 03, 2008
    President:
  • 814 Answers
This unit has had a failure in the power inverter board or in the backlight lamps. The unit should be sent or taken in to a service center for complete testing and servicing. They will have all the service information to evaluate and repair your monitor. The customer support website is www.fourstari.com. I hope this information helps you with your problem.
Welcome to Fourstar Group's customer support site. The purpose of this Web site is to enhance the support services we provide to our customer's customers. We've provided a number of resources here to help you report and resolve problems, suggest improvements and learn about our products.
Things to have on hand for support
  • Item #
  • Model #
  • Original receipt
  • Store name
  • Purchase date
  • more
Technical Support Information Technical support is offered Monday - Friday* *9 a.m. to 5 p.m. (EST).
*Closed major holidays and the day after Thanksgiving
Phone : (508) 435-4830 or (800)-639-3803 E-Mail : support@fourstari.com
E-Mail : ayuda@fourstari.com
Services Automatically submit!*
Posted on May 23, 2009
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Monitor is showing bottob half display and upper half is blackout
Hate to say it, but time for a new monitor... will cost you WAY more to fix than to pop-by a garage sale and grab a new monitor.
(It's not even worth a repair-persons time to do it...)
Aug 31, 2009 | Philips 105S51 15" CRT Monitor
MONITOR DISPLAY PROBLEMS
the display has a loose connection in every side. try pressing the both side by hand.
Jun 14, 2009 | Computers & Internet
Compaq WF1907 Bottom brighter than top
The last 3 monitors I bought all have this problem and all three were different brands. I sent one model back a few times, and the replacement monitors all had the same problem to different degrees. To me, this problem is glaring--the tops seem too dim and the bottom is at least twice as bright looking straight on from about 1.5 feet away. The thing is, most people will never notice it because of the gradual way the brightness changes. Anyway, at this point I feel qualified to say that (at least for 24 in. monitors in my price range) this is the norm. I'm afraid we have to live with it or pony up some extra dough.
Dec 28, 2008 | HP Compaq WF1907 Monitor
Starlogic monitor under warranty
take it back to the local store where you bought it. or
check their website to know where to take it to
Mar 24, 2008 | Star Logic 17" LCD Monitor
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Star Logic 17" LCD Monitor Logo
969 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
