Question about JVC Car Audio & Video
Jvc kd r601 wont store radio stations or save the clock once i turn ignition off and resets itself
SOURCE: KENWOOD KDC - W312SAY BUTTON MEMORY 1 - 6 NOT WORKING
It sounds like you have not connected the B+ Battery backup wire so it retains all memory (radio stations & CD track info). There are 2 power wires (RED & YELLOW). 1 of them labelled B+ need to be connected to a permanent 12V supply and the wire labelled ACC needs to be connected to the ignition switch.
Posted on Apr 03, 2009
  • 74 Answers
SOURCE: Trying to set clock time
http://resources.jvc.com/Resources/00/01/15/GET0582-
001A.pdf
you will find the instructions on the link above
Posted on May 12, 2009
SOURCE: need manuel or how to set clock
Are you sure that is the model number? I looked it up and that isn't a model number for a JVC.
Posted on May 13, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: How do you set the clock on JVC KD-AR470
Here's a link to JVC's download page for this model. Both the installation and owner's manuals are available. You should find what you need there.
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: How do I preset radio stations on my JVC KD-S27?
ussually all radios you choose your station than take the button that you select and hold the button for a few seconds and that should be it !!!
Posted on Sep 01, 2011
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
After market receiver periodically resets itself (JVC KD-DV5300)
In KD-DV5300, replace capacitor C751. Capacitors dry with age.
Feb 16, 2012 | JVC Car Audio & Video
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
JVC KD-R312 CD player keeps resetting itself whenever the ignition is turned off. The radio stations are ok, but mybass, treble, loudness etc always resets itself. Is annoying because i ahve to go through...
You are losing the permenant 12VDC on the Radio. This is the thick yellow wire from the radio loom, it has to be connected all the time to 12VDC.
Cheers
Oct 27, 2010 | JVC Car Audio & Video
I installed my JVC KD-SX650 and it works but when i turn my truck off it loses the radio station and clock settings, what could be the problem?
There should be a yellow "accessories" wire that controls the memory to the radio. If it is not properly hooked up, the radio will reset every time you turn off the ignition.
NOTE: It might be a different color than yellow, but this is the most common
Jul 13, 2010 | Car Audio & Video
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Turns on then off right away
Hello headbanger42,
First I'd check all of the wiring and connections. Make sure that there's no bare wires, no cut or frayed insulation and no wires contacting metal on the vehicle or other wires.
If everything is connected properly and there's no shorts, press the reset button on the panel holder using a ball-point pen after detaching the control panel. (The clock setting and preset stations stored in memory will be .)
If that does not work, there's most likely an internal fault and the receiver needs service.
Hope this helps.
Jun 02, 2009 | JVC KD-SX980 CD Player
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 16, 2009 | JVC KD-HDR1 CD Player
EXAD KD - AR5000 Programming
Do you also lose your clock and radio station presets?
Nov 08, 2007 | JVC Arsenal KD-AR5000 CD Player
Car Audio & Video Logo
63 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
