Question about Zanussi Washing Machines
My zanussi swg 1200m is coming up with fault code E21 and I can't open the door, how do I open it?
My washing machine is coming up with code E21 and won't open, how do I open it?
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 106 Answers
SOURCE: washing machine keeps stopping mid wash and coming
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Posted on Feb 27, 2009
rdrsp
  • 85 Answers
SOURCE: Zanussi washing machine type ZWF 1217W Flashing
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts: Take the top off the machine, (ENSURE IT IS UNPLUGGED) and on the right hand side of the machine, you should see a set of 4 blue wires that go from the electronics module to the front display unit. Take this plug off (it is held on by plastic retainers) clean with wd40, or silicone contact cleaner, then dry, replace, then try again. If it is very badly corroded or pitted, you may have to replace that part of the wiring and socket.
If it is not that, then the wiring to/from various other sensors could be damaged, or the control board could be faulty. It is probably worth checking around other plugs and sockets, re-seating each one in turn, that lead to the control board, before calling an engineer in, or getting a spare board, as they are expensive. Pulling off and plugging back on (Re-seating) the plugs and sockets has the effect of cleaning the contacts, and may fix certain intermittent faults like this. Obviously check for any plugs/sockets that appear burnt, corroded, or discoloured compared with the others, and clean the contacts with emery or a needle file.
hope this helps....
Posted on Oct 25, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
Sep 30, 2016 | Zanussi Washing Machines
My zanussi washer is coming up with error code 40 anyone no what it is
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
Dado
Aug 27, 2015 | Zanussi Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
Door on washing machine is locked with e20 code
This particular code is used when the machine detects a pump problem or water draining problem. In this case, the fault would occurr just before attempting to spin. It turned out to be a blocked filter, accessible from the bottom front of the machine. so the best thing to do is clean the filter on the front of the machine open the flap and undo the filter water will come out so be ready for that. after it is cleaned and filter all back in and secure switch machine back on at plug and run cycle this should fix it. hope this helps.
Here are some error codes for future problems. E10 - not filling
E20 - not draining
E40 - door open
EFO - Filter blocked
Sep 19, 2010 | Zanussi ZWD1270 Front Load Washer / Dryer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint WMA30 Front Load Washer
Oct 09, 2008 | Washing Machines
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
35 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
