Question about LG WM-2277HW Front Load Washer
LG washing machine WD-80154tp show the error code PE
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
SOURCE: error code PE on top loader(LG)
Check the pressure switch -the system that determines correct waterlevel in the drum. If its giving an incorrect indication to the programtimer machine will either overfill, refuse to fill or refuse to spin.Its an air operated diaphragm switch triggered by rising air pressureinduced by the entry of water into an airtight vessel attached to thebase of the drum. It tells the program timer that the water has reachedthe correct level, allowing it to proceed to the water heating stage inthe cycle. Power off, drag machine out onto the floor, remove backcover and top cover. The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. It generallysits just under the top cover. Disconnect the thin rubber pipe from theswitch and blow down through it to clear any blockage. Switch itselfmay be faulty but its more likely the pressure pipe or the vesselattached to the other end of the pipe is blocked. Some machines havethe pressure vessel integrated as part of the filter unit, with apressure chamber moulded into the top of the filter body. Remove thepressure vessel, put a small nut or screw in it, fill it with water andshake vigorously till any crud or residue is removed. Refit all parts,check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at thefoot of the machine.Some are obvious like little square hatches andsome are hidden behind the trim panel at the foot of the machine. Oncepanel is removed the filter should be visible. Its generally a circularplastic fitting which unscrews in an anticlockwise direction. Somehotpoint, indesit and ariston filters are located in the big black sumphose (the one that leaves the bottom of the outer drum and connects tothe pump). Power off, drag machine out onto the floor, remove backcover or tip machine up at an angle. Locate sump hose, remove thetensioner clip by squeezing the tabs together with a large pair ofpliers or vise grips, remove the hose, take out filter and clean. Beprepared for spillage of water. May help if the machine is tiltedbackwards at an angle.
Repair and service your own washing machine. Go to www.2ndwave.co.uk/manual.html
Posted on Jan 13, 2009
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
I have an lg front loading an it showing pe signal
the PE error code is a power error code normally happens when there is a power failure you can turn the washer off then back on (not unplugging it) and this will clear the error code however if it happens with out any other reason then there maybe a power problem inside the diagnostic computer in the washing machine
Aug 05, 2016 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
I have problem in my lg wd-80154tp i press play butten it off
This can be due to errors on the board or it can be related to fault in the inlet valve or control panel.
Check and see if there is moisture within the board or the panel that can cause errors , if so use a dryer to warm off.
If not the board is a suspect.
Feb 07, 2013 | Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
96 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
