Question about Westinghouse SK-26H240S Television
Westinghouse flatscreen sk-2640s tv - no picture no sound
My westinghouse flatscreen sk-2640s tv has no picture no sound, Its 11 months old. worked fine for first 8 months and then picture went; when i turned it off and turned it back on go no picture and no sound. after a few days it came back on iits own. Now the same thing has happened again only its been a week and its still dead. is there any fix? is this a common problem with all flatscreen lcd tv's or just westinghouse?
  • jtwade Dec 29, 2008
    Had it for about 14 months. Suddenly lost all signal from both of the inputs I use (video in or cable/co-ax). TV doesn't respond to any controller commands or side buttons other than off/on switch. That works both the side button and the controller. When power comes on, sometimes the screen is bright white, other times, a dark gray. Either way, you know it is on but no signals are being processed.
5 Suggested Answers
SOURCE: Westinghouse SK-32H540S LCD TV Turns Itself On - Appears Random
turn the timer off.
Posted on Jan 27, 2009
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
  • 117 Answers
SOURCE: Westinghouse Flat Screen TV will not power on
caps in power supply
Posted on Jun 23, 2010
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
Jul 25, 2012 | Westinghouse SK-26H520S 26 in. LCD HDTV
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Our TV picture works fine then blacks out with audio continuing to work ok.Now after some time picture works ok for about 20 seconds the blacks out with audio continuing on OK.While we bought this in 2008...
I think you chose a Westinghouse Lemon, go this site and read all of the negative reviews of this model;
http://reviews.cnet.com/flat-panel-tvs/westinghouse-sk-32h240s/4852-6482_7-32429419-2.html?tag=userReviews;page
Here's just one of the reviews;"best chunk of aluminum i ever had the fortune to buy"by stevecox25 on June 11, 2009-->
"Horrible customer service on a worse television" by westinghousecrap on March 20, 2009 Pros: Good picture once it is properly adjusted.
Cons: Low quality audio, had the TV for 10.5 months and the picture went out, sent the TV at MY expense to TX, and I've been waiting for 2 months, and customer service can only say that there is a "delay". And they don't send a new TV, it's a rebuild.
Summary: Please don't waste your money on this TV, spend a little more on a different brand and save yourself the headaches I've had. I'll never purchase a Westinghouse product again. Customer service has been no help, and their answers are vague at best. Learn from my nightmare, NCAA march madness on a old 19" TV because my Westinghouse quit working 2 months ago and they still haven't replaced it.
Aug 22, 2010 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
Tv will not turn on. power cord is good.
I have a Westinghouse Mod. SK-19H210s that is 16 months old. It would not turn on. Upon investigationg the problem I discovered bad capacitors on the power board. (2200uf and 1000uf). I replaced the components and the TV works great, you can purchase a new power board.
Jul 13, 2009 | Westinghouse SK-19H210S Television
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
408 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
