Question about Bosch Washing Machines
My bosch exxcel washing machine has a flashing key symbol on the electric counter and repeatedly beeps. I cannot reset this to continue using the machine. I have tried turning it off at the mains and leaving it but this doesnt work. What can i do Read more: My bosch exxcel washing machine has a flashing key symbol on - JustAnswer http://www.justanswer.com/uk-appliance/1tomh-bosch-exxcel-washing-machine-flashing-key-symbol.html#ixzz1mokdRprz
dauphine
  • 207 Answers
SOURCE: there is a key symbol
The machine won't start because the door isn't properly closed. However it might be that there's a problem with electric door lock itself. Try pushing the door a little bit more in to see if the lock will "click".
Posted on Apr 16, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Posted on Jan 07, 2010
  • 457 Answers
SOURCE: I have a bosch exxcel 1400 express and a key
check the manual . you can take the key mode off with the instructionsprobably a press and hold for 2-3seconds thing .If you dont have the manual you can get it from thermador. com they will order it for you. you will get it 2-3days. let me know how you made out:)
Posted on Feb 26, 2010
FixinFax
  • 3085 Answers
SOURCE: what does the key symbol mean on the Bosch Exxcel
The door is locked.
Posted on May 30, 2010
Daniel S
  • 4323 Answers
SOURCE: Bosch Exxcel WAE244S0GB machine won't start,
Hi
If the beep sound is coming from the dial not from the bottom where the motor is then the issue seems to be with the Timer/control board going bad and needs to be replaced. However, you can unplug the unit and then blow some air with the help of hair dryer before replacing the Timer motor/control board. If the sound comes from the motor area then it is the motor that has gone bad and should be replaced. When the motor goes bad it will fill with water and empty. One more thing to check will be the door lock-switch assembly, because if the control detects door not locked it won't run cycle and will just drain the water out. Also please let me know the exact key symbol before 0 which is appearing on the panel. Hope this helps... .please post back for further assistance.
Daniel
Posted on Jan 09, 2011
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
