Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Factory reset DMR-EZ49VEB
How do i rest a panasonic dmr-ez49 to its factory default settings
SOURCE: Set Clock Greyed out
I have the same problem - clock set is grayed out. Called Panasonic tech support .. this is the solution I was given. It works, but too bad the root problem can't be fixed (bug ridden unit).
Solution is to "reset" the unit - then go back into the menu system and set the clock. How to reset the unit (don't worry - anything on the HD stays intact):
1) go to DVD mode
2) remove any DVD in player & close tray
3) on front panel, behind door - press & hold BOTH channel up & down keys for 5-10 secdons -- until you see a message that the system is rebooting
4) wait till it reboots, go back in the menu and set the time.
-Craig
Posted on Dec 19, 2007
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
Obertelli
  • 3006 Answers
SOURCE: How do i unlock my panasonic dmr-ez45vebs to play
You need to buy a service remote to do this on your model, but the official service remote costs more than the player and is not sold to the general public.
Alternatively, you can rent a chipped regular remote control which does the same job.
In the UK you can get them from www.multi-region.co.uk
Note that on your model there is no other way to hack the player, it can only be done using the correct remote control.
The remote chips are available separately but are not easy to fit unless you're an experienced electronics technician; you can buy read-chipped remotes but they typically cost the dame as the original player.
I hope that you have found my reply to be of use and only ask in return that you rate my answer.
Posted on Nov 08, 2009
Testimonial: "Thanks for reply"
  • 4 Answers
SOURCE: Panasonic DMR-EH57 Unlock codes
send it or take it to your local authorised panasonic service center, they can normally do it while you wait. If it is under 12 months old then panasonic will normally pay for this, otherwise a small fee can apply, so if you are unsure on who is your local service, either give panasonic a call or check out there website.
Posted on Dec 20, 2009
SOURCE: Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Posted on Feb 16, 2010
I have a PANASONIC DMR-BWT835GL that splits most recordings into 2 segments (with 3-4 minutes between them) and places them into a folder. I believe it occurred after a software update.
Often times this is caused by a new default setting being used after an update.
A couple possible solutions could include:
Look at the settings you set when you record something. Play around with different ones and nake sure it's not a simple recording option.
See if there's a menu for your DMR that you can alter system settings with. (Most have some form of this in my experience)
Hope I'm some kind of help
Oct 12, 2016 | Panasonic Televison & Video
Panasonic dmr-ez49veb wont play dvd-r discs
I would suggest contacting Panasonic support. You can search for their website/home page for their contact numbers. Typically, manufacturers maintain help, support, upgrade, forums and FAQs/knowkedge bases to help customers troubleshoot their appliances/equipment. I have used similar methods, previously, to update/upgrade the firmware on an "obsolete" DVR and it has lasted 4 more years (still working).
Apr 25, 2017 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr es20 frozen
Hello
Unplug the DMR from AC mains socket, and replug it after 5 minutes. If this does not help you, make a factory reset to this set. Get into the user manual, and there is proceedings how to do the factory reset.
Mar 05, 2012 | Panasonic Televison & Video
L.S. How to reset Panasonic DMR-EH55 DVD Recorder / HDD Recorder to factory settings?
You can either go into menu (pressing 'FUNCTIONS' button on remote) and look for 'RESTORE DEFAULT SETTINGS' or similar heading, or you can (while unit is on) on the front of the unit (not the remote) press CH UP and CH DOWN buttons together for 5 seconds - the unit will switch to standby. Give either one a try. (refer to page 60 onwards in your user manual - these pages detail 'settings').
If you cannot find your manual, it is available for download (free) - http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Operating-Instructions/model.DMR-EH55S.O#ts
I hope this helps in some small way. Thanks for asking FixYa!
Feb 12, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Brand new dmr-ez49veb,has worked ok on setting it up.it is now stuck in vhs mode and will not respond using remote to select tv mode.I have scart and hdmi connections to tv and have tv input selected to...
i have a panasonic dvd rcorder / video combi model DMR-EZ49VEB. I have recorded something on DVD, which is 4 hours in duration, and I want to edit the recording and split it into parts. I follow the manual, but when I press EDIT the option to split isnt even there? I am confused, it is SUCH a difficult manual to deciphre, but the only 2 options there are "Edit title name" and "Change Thumbnail". The others are not listed. the disc is not copy protected or locked and is of sufficient duration to split the contents. HELP PLEASE :(
Dec 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
490 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
