Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman Propane Furnace Good pilot light but feed/ignite main burner
Have a Coleman furnace that has a problem. I can light the 'standing' pilot light with the striker and after the thermocoupler heats up it stays lit. However I can no longer get the main burner to light.
I have checked power (13.2V) to unit. I have checked the thermostat ( functioning). The thermocouple works and holds a good flame.
The two white wires in the accompanying picture attach to the blue screw leads at the front of the gas valve. They are for the thermostat control.
The switch located on the mid-right side is for power. Red is 12V,blue is common, and white is return from the thermostat.
The thermocouple is at the back of the gas valve on the right side of the picture. You can see 2 tan colored leads coming from a secondary sensor control. Thermocouple itself is the copper line that screws into the valve.
Behind this thermocouple is a solenoid of sorts.
I am suspiciouc that this may be the problem since I can't seem to get the main burner to take gas but I need help to detrmine how to diagnose if this is the problem or not.
Then if it is, where do I get parts for a 20 something yr old furnace??
  • BrianG Smith Nov 24, 2008
    Thanks for your advice.
    It was the coil /plunger valve within the gas valve itself. Not sure about what you are refering to re: transformer. Since the gas valve is millivolt based there is no step down from a 110V AC source. That may not have been clear in my posting.
    You are not allowed to rebuild them so I was able to find thru a dealer in Duncan BC, Pete's RV, a universal replacement. I have since installed it,and it works like new.
  • effie99 Dec 28, 2008
    I have no voltage at the thermostat or at the 24 V transformer. I have 120V coming in to transformer, but nothing coming out. I have also tried the man. reset, nothing to reset-switch is still "down".
  • 306 Answers
If you have a volt ohm meter take the two leads off the gas valve and ohm out the connection should have resistance for the coil. You said you have 12 volts from the thermostat white and red in the heating mode you should have minimum 26 volts. If you want to check the transformer should have 28 volts. Almost sounding like the transformer is getting weak. You can get parts for a 20 year old unit at any HVAC parts house. Try Washer Specialties here in Wichita Kansas they are on the web. Lowes even carries Transformers. Has to be rated 120 volt primary side secondary side 24 volts and 40 VAC.
Posted on Nov 24, 2008
How do I light pilot light?
There should not be a pilot on a direct vent furnace. When you turn up the thermostat for heat the 1st thing to happen is a venter motor should start, it should vent for approximately 45 seconds, the air switch will verify a vacuum in the burner box, then a spark igniter should start clicking to start the pilot, then the flame rod will verify the pilot, the igniter will stop clicking, and the main burner will ignite and remain on until the thermostat has satisfied the set point. These guideline steps must be satisfied before the controller advances to the next step. The 1st step is the venter motor running, sometimes the motor will stick over the summer months, spin it manually to unstick it. PS, nothing runs if the fan door cover is open, as that shuts down the power to the whole furnace.
Oct 02, 2015 | Coleman Gas Fired Mobile Home Furnace,...
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
I have an old Coleman Presidential propane furnace. The other day the furnace quit working. I checked and the pilot was out so I relit it and positioned it back to on. The main burner then ignited but only...
Try taping assembly the pilot with a screw driver sounds like a dirty pilot and when the flames come on the pilot pulls away from the thermal couple but tap it when the pilot is lit not the burners
Mar 22, 2013 | Heating & Cooling
My furnace wont come on its an automatic pilot so i dont know what the problem is we have enough propane
Hello, Most newer gas furnaces (propane or natural gas) has one of several different types of igniters. The most common one is called a hot surface igniter. This is a ceramic easy to break, glow coil, glowing igniter. Some has a Spark igniter that lights all the burners from a constant spark and some light the burners off a pilot proven /spark igniter. This one sparks then lights a pilot then the burners will come on. In any case if any of these types are not working they could be cracked or broke. Also the inducer draft motor has to be running, the little motor that hooks to the exhaust of the furnace ( if it has one ). This causes the pressure switch to close then the igniter should come on. My suggestion is to call a qualified service tech from your area to assist you. To determine which one of these may be your problem they will have to perform several test. Hope you get going soon. I hope this helped. J
Jan 27, 2011 | Coleman Propane Forced Air Heater...
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Heating & Cooling Logo
746 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
