Question about Candy Washing Machines
Candy washing machine EMI filter!
No LED on but ceackling noise from EMI filter ..
SOURCE: Candy Activa Smart 1300 AA
Many thanks had already done this and all is working fine now fingers crossed!
Posted on May 31, 2008
barkencoa
  • 3463 Answers
SOURCE: Need to know where the
If `there is a removable plastic panel at the bottom front of washer, remove it ,and you should the filter there if it has one fitted
Unscrew the cover anticlockwise, remove and clean.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
  • 6277 Answers
SOURCE: I can not find the
Here is my generic 'standard' document ;-0)
It's quicker than typing it every time and I hope it helps!
Sorry but I do not know your particular machine BUT it is normally behind the front lower (kick) panel (or for some washers in a more awkward position at the back) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Feb 14, 2011
  • 6277 Answers
SOURCE: I cant remove the filter on my Candy AQW Washing
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Apr 05, 2011
KevinWhite
  • 1902 Answers
SOURCE: Candy Grand 1600 AAA class
Hello & Welcome to FixYa
You can start with cleaning the drain filter pump assembly located inside the front bottom panel of the washer. After it's cleaned and the problem is back then replacing the control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jun 19, 2011
My candy go w475 washing machines stop working, the stop buton flashing all the time, colse the door but still flashing any help plz
clean the filter empty the machine at the drain filter !!!
check for rubbish in the pump viens {power OFF}
kirby grips clothes wires coins etc
perhaps you dont have the manual how to keep it clean
http://www.manualsdir.com/manuals/242947/candy-go-w475-s.html
Dec 04, 2014 | Candy Washing Machines
How to open filter on candy ctf 1005?
in the center is a screw you need to use a wide big flat driver
to carefully losten it anti clockwise
once its loose
you can use a cloth grab the center hold of the round pump cover and rotate it anti clockwise
the screw in the center is just used so the kids dont fload the house
Jul 27, 2014 | Candy Washing Machines
Wash cycle stops and light on the extra dirty symbol lights up
This is might be the drain filter. When the drain filter is clogged, the machine won't empty itself of water.
Candy has a troubleshooting webpage that lists many possible problems/solutions:
http://service.candy-domestic.co.uk/fault-finder/FaultFinder.aspx?Section=11
If you do try to check the filter, keep in mind that opening the drain filter will yield gallons of water on your floor, especially if your machine does not have the drain hose next to the filter opening. You'll need to have some way of transferring the water ready before opening the filter.
Good luck from Detroit, MI.
Jul 18, 2011 | Candy Washing Machines
Making a noise when spinning like there a coin inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hdgket
Nov 29, 2009 | Candy CNW136 Front Load Washer/Dryer
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
Loud Loud Noise and a jumping machine on spin mode
hi it may be the belt problem ...better to change it thank u....
Jun 03, 2009 | Candy Washing Machines
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
