Question about Denon Audio Players & Recorders
Have a denon avr 1312 and i cant get sound from my ps3
I have plugged into my ps3 with a hdmi and everything looks good but i just cant get any sound coming from it, i get sound from my xbox and tv but nothing from my ps3 picture is great i need sound
VOTIT
  • 2071 Answers
SOURCE: trying to install my denon
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: connecting PS3 to Denon AVR-3805
refer to manual
http://www.playstation.com/manual/pdf/PS3-01-1.0_2.pdf
think you can use AV multi out connector
Posted on Nov 25, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: connection problem with HDMI cables on Denon AVR-589
Hi dmsgolfer22,
If your Time Warner Cable box is old enough that it has a DVI output it may have HDCP (copy protection issues) with the receiver. If you are having to use a DVI to HDMI adapter to connect to your receiver (output from Cable Box to input on Receiver) then it's very likely your cable box may have may not output the signal because it detects the HDMI repeater in the receiver.
The two best options to correct this are:
1. Connect the DVI to HDMI cable directly to the input on the TV, you lose the convenience of the video switching in the TV, but it will solve the problem. Then connect the digital audio output from your cable box to the receiver, although you've probably already done this.
2. Contact your cable provider and check into the possibility of them swapping out your cable box for a newer model that would have an HDMI output. This would be the best option since the HDMI output on the cable box would give you both the Digital Audio and Video through a single HDMI cable.
Let me know how it works out for your, or if you have any questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Posted on Feb 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 2106 clicking noise
I like when a user is observant and curious. That will help immensely in resolving this problem.
What source(s) are always involved with the problem?
You imply it is observable with output video to the TV - "only when there is movement on my tv screen and it stops in still screen". That sounds like a digital pathway problem of some sort as any data errors would eventually escalate to something audible or visible to you once the hardware and correction algorhythms are exhausted. The clicking inside the receiver could be its efforts to resynchronize with a bad data stream. Hence, I'd like you to isolate the ins and outs that fail all the time and find the probable single source of the problem.
Try this: put a digital source on and select/deselect it for listening or viewing. Does it make the click in that brief time it's 'thinking' before you hear the source? That would be the 'normal' sound. My Pioneer does it once per source switch. Repeated clicking would mean it's struggling.
I'm betting you have an optical or hdmi cable that's flaky or not in tight and straight. Or, if only one extternal source is involved we follow that back.
Posted on Apr 29, 2009
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
I have a denon avr-x2000 all hdmi ports except the cab/sat are fuzzy. it started with the PS3 on the game port
Plug your ps3 and/or blu-ray directly into the TV and see what it looks like. use different HDMI cables to test them. Once you know that all works then setup your avr-x2000. Does the Denon menus look fuzzy?
Mar 20, 2014 | Denon AVR-X2000 In-Command 7.1 Channel 4K...
Can I get audio out on a denon avr-1312
what are you wanting to audio out to? the AVR is the audio component of a setup so am unsure as to why you would want to
Feb 27, 2014 | Denon AVR 1312
Denon avr-1312 receiver and mitsubishi hc3000 projector - Video keeps dropping out
Hi, it could be a number of things, go to your browser type in the model followed by support, look at there info, is there enough life in the bulb? if it were mine i would clean the shutter and go on from there but try that what i have said example >>.denon avr-1312 support << hope this helps :)
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
My denon avr 1312 does not start. the power butten is red but not flashing. display off. no reaction whatsoever. any ideas?
unplugged the unit and do these reset
if these have already been done, and symptoms persist
the unit needs servicing.
Aug 20, 2012 | Denon Avr-1312 Home Theater Av A/v...
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Connect wii to Avr 1312 Denon
What you would have to do is connect the video output of the wii directly to the video input of the bug projector. Also connect the audio cables to it as well. Then connect an audio cable to the projector's audio out or otherwise labeled as "variable out" then connect the other end of that to the matching input terminal, found often labeled as "audio in" on the receiver's grouping of input selections for TV.
Then, on the projector, select the video mode you connected the wii cables to.
Jun 18, 2012 | Denon AVR 1312
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
149 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
