Question about Nintendo Wii Console
WII wireless reveiver cord not long enough
I put the WII in and the receiver module cord attached to my console is about 15 to 20 feet still too short. When I play WII I have to face to the right of the TV. Is there a wireless solution? or extension cord for this USB looking cord connection?
  • 55 Answers
Error code 11182
Katie that may be a Wii support code.
Wii Support Code: 11182 - Successful connection test
If you receive a this code, your Wii was able to successfully connect to your wireless network.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wii Error Code Lookup
Nintendo Customer Service Nintendo Wi Fi Connection Support Code Results
Mar 30, 2016 | Nintendo Wii Console
Wii remote does not have little hand/arrow
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Click here to download repair guide
Dec 26, 2010 | Nintendo Wii Console
My wee console has been chipped but the censor cannot pickup the remote contrlol
First, follow these guidelines to ensure you have set up the system properly to have optimal environment in which to use the Wii Remote:
or Click here to download repair guide
Dec 24, 2010 | Nintendo Wii Console
Wii lost connection to internet how to reconnect
FIRST, you want to check and make sure that your router is working and sending a network signal. When you find that it is and your Wii still won't connect, try moving your router to a better location where the wii can receive the signal more clearly. Then go to the Wii "Options", then Wii "Settings, Scroll through screens to "Internet" option, then "Connection Settings". Choose your Wireless Connection that you were using and do a "Connection Test". Sometimes it's only a matter of a couple of feet and the signal won't be strong enough, especially if the Wii and the router are in seperate rooms. If all else fails, simply clear the settings for the wireless connection you were using and start from scratch by re-entering the connection settings for your home network. Hope this helps!
Nov 30, 2010 | Nintendo Wii Console
The wand does not work the movable hand
Hello :
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote.
1:Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen
2:Make sure you are using fresh batteries in the Wii Remote
3:The Wii Remote Controller should be used between 3 to 10 feet from the TV
4:Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote
5:Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves
6:Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
good luck .
rate please .
contact again if that didn't help please !
Mar 20, 2010 | Nintendo Wii Console
Hooking it up to the internet
Actually the Wii comes standard with wireless. You should be able to detect a wireless network with ease.
Feb 20, 2010 | Nintendo Wii Console
Problem attacing cords to wii
You will need to buy HD leads for the Wii. You can pick these up for a cuple of punds on Ebay. Although you will only get the resolution to about 560i.
Dec 05, 2009 | Nintendo Wii Console
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
No sound transmitting from Soundstation EX wireless mic # 2201-00699-002
confirm that you select aux input in your soundstation2.-if your problem excit change audio cord between receiver output and the aux.
Oct 17, 2007 | Polycom SoundStation EX (expandable)...
Nintendo Wii Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
