Question about Dell Computers & Internet
Dell Monitors Hiss sound Problems ST2010 20 inch LCD Monitor
  • 286 Answers
SOURCE: LCD causes self-test to fail
Looks like you have a shorted IC ot transistor on the LCD layer of the panel.
If you remove the screws from the back of the panel and look underneath, you will see the circuit the main board plugs into. Usually there are a few components on this pcb that can go bad. Replacing them is a little hit and miss. If you can identify the component, you might stand a chance. I had a unit do this, and when I looked at the lcd pcb there was a shorted smt transistor. It was burnt, but I was able to remove it without damaging the board.
I managed to replace it twice with two similar transistors, but the panel still caused the power circuit to cycle when I plugged it in. Although I couldn't find any other shorted parts, the small smt ICs on the board could have had internal shorts, or the transistors I used to substitute were completely wrong for the circuit. Since the original transistor was burned, I could not identify it in any way.
The only hope for your monitor is to identify and replace the bad smt component on the LCD board, or replace the lcd layer itself. I've done this a few times, but it requires another of the same panels, one with a bad backlight perhaps. If you are careful enough, you can remove the metal frame assembly from the panel (there are usually four screws, two on each side). You will have to "unsnap" the outer frame from the inner frame all the way around the outside.
Do this to both panels, and place them face up on a desk or bench. Carefully unwrap the ribbon cable and remove the entire lcd layer. Do this a second time, only place the working lcd layer over the working backlight assembly. Make sure the lcd layer seats snugly in the frame and wrap the ribbon cable over the top. Reinstall the outer frame. You have to make sure everything stays aligned as you snap the outer frame back into place. Reinstall the screws. Now you should have one perfectly good lcd panel. Keep an eye out for a panel with a bad backlight.
Posted on Mar 27, 2008
worldvet
  • 859 Answers
SOURCE: Dell LCD monitor suddenly loses power
Five years is a long time for an LCD panel. You definetly got your money's worth.
But, if your trouble shooing has led you to this conclusion I can also only conclude that the power driver inside your panel just gave up the ghost.
However, try giving Dell a call, for what's thats worth and see what they have to say.
You might also want to ask this expert "Robotek" what he may think as he is a board troubleshooter and could give you an answer if one is there.
Type this or copy and paste into your browser's address bar:
http://www.fixya.com/users/robotek
And then click on the Ask Me button under his picture.
Best regards,
Worldvet
Posted on Jun 21, 2008
ginko
  • 19396 Answers
SOURCE: Monitor Problems
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Posted on Sep 09, 2008
mcdevito75
  • 1970 Answers
SOURCE: My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Posted on Jul 14, 2010
budmrtn
  • 11361 Answers
SOURCE: samsung gh19ws (920nw) model lcd
Common problem is in the DC filter caps in the power supply circuits, that will be the first thing to look for first, please note that bad cap can look normal but can have high ESR.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 23, 2010
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
Do any of your dell 17 inch monitors have built in speakers?
17" Dell monitors don't have speakers, as a matter of fact, I haven't seen any Dell monitors with speakers.
Feb 19, 2014 | Dell E173FP 17" LCD Flat Panel Monitor
Screen Too Bright
Do a factory reset on All Settings:
http://support.dell.com/support/edocs/monitors/se197FP/EN/ug/setup.htm#Using_the_OSD
Dec 06, 2009 | Dell SE197FP 19 inch LCD Monitor
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
I have 2 identical monitors that i use for my studio
They are sitting right next to each other?
sometimes you have to space electronic out, due to there out put... if they are really close to each other try moving one and see what happens.
hope this helps
Jun 05, 2008 | X2Gen MG19MY 19" LCD Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
Alun Cox
