Question about NetGear WGR614 Wireless Router
I want to secure my netgear wireless router - NetGear WGR614 Wireless Router
    Sergeant:
  • 264 Answers
Open the Interface of the netgear router. Go to wireless and further go to wireless security.
Select the WEP option in the same.
Do not Type anything in the PARAPHRASE
In the Number 1 feild type a 10 digit password.
Save all the settings and log out of NetGear.
Now you will have to use the same password to connect to the Wireless network,
I am sure that this would help
Please do rate the solution
All the Best
Sammy
Posted on Oct 27, 2008
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
Loss my netgear wireless security password,
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2012 | NetGear N150 RANGEMAX 150 Wireless Router
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
How do i reset or changed the password of my router (netgear wireless router MR8v2)?
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Sep 16, 2011 | NetGear MR814 Wireless Router
How do I secure my Netgear router?
To secure your NetGear Router follow the instructions at the link below:
.../Netgear/WGT624/wireless.htm.. <<
Sep 11, 2011 | NetGear WGT624 Wireless Router
IT SEEMS LIKE OTHER PEOPLE IS STILLING MY WIRELESS. TELL ME HOW TO BLOCK IT
Use WPA-PSK and WPA2-PSK. WEP security is not secure at all. Change your SSID to something you recognize. The default is NETGEAR. everyone who buys a router may have this name. MAKE it your own SSID NAME
check in the DHCP client list to see if only your pc's are attached. I am sending a user manual link to get you started.
ftp://downloads.netgear.com/files/WNDR3400_SM_23MAR2010.pdf
This is a tutorial for the netgear router in general to make a secure network for wireless.
http://www.ehow.com/print/how_5008833_set-secured-wireless-network-netgear.html
Mar 24, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
Jan 29, 2010 | NetGear WGR614 Wireless Router
I HAVE A NETGEAR WIRELESS ROUTER AND I NEED TO SECURE THE NETWORK SO OTHERS CAN'T ACCESS THROUGH MY COMPUTER
If you configure the Netgear wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings, then other computers cannot access your router wirelessly unless they know the encryption setting. Please click on this link and follow my instructions to secure your wireless router :-
Jan 06, 2010 | NetGear WGR614 Wireless Router
I just got a netgear G wireless router and i cant figure out how to secure it i have internet access
Following site has steps of securing Netgear G Wireless router:
http://webupon.com/security/securing-a-netgear-wireless-router/
http://www.trueblade.com/knowledge/using-wpa-psk
Use the one which is more appropriate to you.
Hope that answers the question.
Nov 04, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
46 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
