Question about Brother Office Equipment & Supplies
Brother 8890DW MP tray feeder won't activate
Appears to be a mechanical problem. I slip paper or envelope into MP tray, so that detector is lifted up a bit. Normally, nothing further needs to be done. Ths signals the machine to draw paper from the MP tray tray rather than T1. But nothing happens.
Rubec
  • 42 Answers
SOURCE: Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
Posted on May 11, 2008
SOURCE: Brother MFC 8460N All in one
Remove your tray.
Push it from the back and make it sure it's tight against the paper.
Move the blue button to the "unlocked" position.
Should be good to go!
Posted on Jun 18, 2008
SOURCE: Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Posted on Sep 18, 2008
  • 215 Answers
SOURCE: Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
  • 10 Answers
SOURCE: my lexmark t520 says "load mp feeder letter"
Easy one. Open your tray back up and make sure that the paper settings are reflecting the type of paper that is in the tray. The times that I have seen the issue that you just described, the paper setting were off... thus causing this issue.
If that does not work. Powercycle printer. When it comes ready go to the Paper Menu, then to Default Paper source. Make sure that setting reflects the tray that you would like the printer to print from.
Hope that helps.
Posted on Mar 19, 2009
How doe I fix the "no paper" fill paper in the mp tray?
The MP (Multi Purpose) trays on this model are behind the machine in the back. There is a cover which can be unlatched. Unlatch it and slide the tray out. Insert up to 50 sheets of paper or 3 envelopes.
Here is the PDF manual. What you want is on page 12 http://download.brother.com/welcome/doc002444/cv_mfc8480n_usaeng_usr_lx2704001.pdf
Here is the manufacturer link for any other concerns regarding this model.
Manuals MFC 8890DW United States Brother
Nov 26, 2015 | Brother MFC8890DW AllInOne Laser Printer
I have Brother Printer MFC-8890DW. It says no paper but there is paper in it. The red light is on. Please let me know how I can fix this problem. Thanks.
If your printing from windows you might need to change the tray settings in the driver.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347&Sympt=When+I+try+to+print+from+Microsoft+Word+or+another+program%2c+I+receive+a++message+stating%3a+No+Paper%2c+Reload+paper+in+MP+Tray+or+Insert+Paper+Manual+Feed.++What+can+I+do%3f&Model=1365&ProductGroup=5&Keyword=no%20paper&ProductID=MFC8890DW
Sep 08, 2010 | Brother MFC-9840CDW Laser Printer
Load and print envelopes
Generally NO. The reason is they have a manual slot and rear exit that keeps the path nearly straight for things like envelopes, labels, cardstock etc so they dont have to make the turn from the tray and from the fuser to the fact down exit tray. If you need to do a mailmerge with numerous envelopes you could 1) print a sheet of labels and stick those to blank envelopes or 2) go to a more advanced machine that has envelope feeder capability. Even a used machine such as a Laserjet 4000 - you can find envelope feeders that just attach on easily for almost nothing on ebay.
Jun 21, 2010 | Brother HL-2070N Laser Printer
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
The manual paper feeder will not feed (it is not recognizing the paper as being in the feeder)
On the Manual Feed Paper Tray, there is typically a lever that swings down, about in the middle, which accomodates envelopes, etc. Make sure that theat is not broke off, or wedged up into it's retraction slot. If so, use a tooth pick to try and pop it back down ( the tooth pick should break before the plastic does ), a knife or fork will have no mercy on the delicate lever.
Also, MP Trays have limited capacity.. too much, will not allow the paper to get back, inside far enough, to be sensed.. typically 25-30 sheets.
On the main paper tray, typically, the 'Paper Sensor' is a mechanical tab on the outside of the paper tray. If the tab is broken off, the printer may not 'see' the tray as being inserted. Pull the the tray out, use a vacuum with a skinny crevice tool attachment and **** out any paper debris, dust, etc that maybe blocking an electronic eye, though uncommon for cost reasons, by the thousands and the controlling circuit board that would also be needed also.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
Aug 09, 2009 | Brother BRTHL5250DN Laser...
Jul 29, 2008 | Lexmark T644 Laser Printer
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
