Question about RCA RP5420 Clock Radio
Turn alarm off for weekends???
I can't figure out how to turn the alarm off for the mornings that I don't need to be awaken? The manaul says to hit the Alarm 1 2 Off button - but taht doesn't work??? This thing is driving me nuts!
  • Anonymous Mar 21, 2009
    I have decided to unplug my RCA RP5420 and take it to classes for show and tell on what products not to buy, since the genius that designed the system to where you can never enjoy this clock unless it gets to wake you up even when you don't want to. Not recommended for college students.
If its anything like the RCA model I have, you have to simultaneously hit the alarm button for the alarm you want to turn off AND the off button, so both at the same time.
Posted on Nov 03, 2008
Set time on RCA dual clock radio with fashion wrap? RCR 8622
I love the form of your question, as I wanted to wing the sucker myself, but got online before I actually pulled an Office Space on it. I found nothing, but I DID actually figure it out. Not super intuitive though. To set the time: Hold down the memory key in the middle until the number flashes. Use the arrow up/down on the right to set hour. Press Memory key again, repeat with arrow keys to set minutes. Hit memory key again. Alarm: Press/hold the Alarm button until the Alarm 1 or 2 flashes and press the side you want, 1 or 2, to set. Arrow time up/down, then do minutes, press alarm 1 again, select alarm or tuner, press alarm 1 again. Now I need to see if it will work in the morning. I know the flipping time is set though! Good luck. If you wing it, please post photos! :D
Dec 11, 2014 | RCA Audio Players & Recorders
Why is my alarm always onn
Alarms are designed to reset every day after you stop them so they'll wake you the next day without you having to do anything. Look for a setting on your clock radio that lets you turn the alarm completely off. You'll be able to tell when you've succeeded, because the indicator on the front panel that shows whether an alarm has been set will disappear. Don't forget to reverse the procedure and turn the alarm on when you want to awakened the next day.
Oct 08, 2014 | Audio Players & Recorders
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
I recently purchased a 99 pontiac bonneville...was playing with light switches trying to figure out what goes where...after exiting and locking with door lock i noticed the interior lights still...
If you don,t have the remote for the (Alarm) Try end get one for it, Or Have the alarm taken out if it isn,t a factory installed (Alarm)
Nov 07, 2012 | Cars & Trucks
Jeep was overheating, Now leaking transmision fluid and won't start
I don't see how leaking transmission fluid would be connected to the engine overheating, unless the radiator blew up.
You'll need to figure out why it won't start to proceed.
Check for spark and fuel pressure, and of course compression.
Is the check engine light on ?
Jul 09, 2012 | 1988 Jeep Cherokee
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
My 2005 convertible beetle wont drive this morning after a weekend long of alarm going off on its own. what's going on?
your drivers door latch assembly is bad causing the alarm to go off replace the drivers door latch with a new one and it wont do this any more
Mar 02, 2010 | 2005 Volkswagen New Beetle Convertible
Accidentally threw out instructions and can't turn off alarm in a
Just press ALM1 button for a second and it will be turned OFF. Do the same for ALM2.
Mar 27, 2009 | La Crosse Projection Alarm Clock with...
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Weekend alarm cancel function
hit the cancel button then the wake1 or wake2 button as you need to cancel them.
Oct 28, 2007 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
RCA RP5420 Clock Radio Logo
343 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
