Question about Logitech Pure-Fi Express Portable Speaker System for Apple iPod
My pure-fi exss moddle S 00067 won't charge my iPod, it will play music but won't charge it
4 Suggested Answers
SOURCE: Logitech Pure-Fi Anywhere Portable Speakers for
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Posted on Jul 14, 2009
Crenshow
  • 250 Answers
SOURCE: does the logitech pure fi express take the new
Hi Jod,
The Logitech pure fi express only support Ipod/Iphone up to 3Generation, please note that Iphone 3GS is not currently supported.
Thanks and have a nice day
J -
Posted on Jun 07, 2010
  • 102366 Answers
SOURCE: I have lost the user manual that came with my
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/10300
Posted on Dec 02, 2010
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
No sound from my Pure-Fi Express plus into my 4th gen Nan Ipod
Hi, while your pure express plus you just purchased is not playing out any sound is because, the speaker that enable you to play the sound when you play music through the ipod is faulty and it needs to be replaced with another one for it to function properly again.
After changing the speaker that is faulty with a new speaker, you can now start enjoying the music again through the internal speaker.
Take care.
Apr 14, 2010 | Apple iPod nano
Malfunctioning connection on ipod ''logitech pure-fi anywhere2''
phoned logitech today who have offered to replace the docking station free of charge as it was under warrenty.Will probably stick with them as a company
thanks for your offer of assistance will bear you in mind for a more complicated problem
Feb 08, 2010 | Logitech 984-000006 Pure-Fi Anywhere...
Buttons wont work on my logitech pure-fi anytime speakers
I have losted three of the buttons on top off logitech pure-fi go anywhere speakers for ipod
Jun 10, 2009 | Logitech Pure-Fi Anytime Premium Alarm...
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Logitech Pure-Fi Elite Speaker System
Two things,
1. You get static charged , from your surrounding ,ie the couch or bed you are sitting in or the the chair you are one before you go and disconnect the ipod.
2. The Logitech is not properly grounded. Check for missing rubber pads below. Also check the earthing at the wallsocket where it is connected
Thanks
proton
Aug 03, 2008 | Logitech Pure-Fi Elite High Performance...
Logitech Pure-Fi Express Portable Speaker System for Apple iPod Logo
155 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
