Question about Honeywell Programmable Thermostat Heater
Coleman heat pump but have heat
Coleman heat pump dont come on but have heat
    Problem Solver:
  • 22 Answers
Well if there is more heating in your heat pump i suggest you uninstall the entire set up and service it once. Its quite possible that it has not been cleaned for quite sometime.
Posted on Mar 19, 2012
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
I have Coleman Heat pump and i want it to conect as AC only any ideas since i changed furnace to gas and the guys dont know how to conect it back as AC only.
Change out the thermostat to a straight cool gas furnace stat.If the reversing valve energizes in cool, simply hook the reversing valve low voltage wire to the yellow compressor wire. If it energizes in heat do not hook it up to anything.
Jul 20, 2009 | Coleman Heating & Cooling
I have a 3 ton Coleman heat and air pump and when I turn the air condition on the heat strip comes on at the same time
If you are calling for heat and the thermostat is set for 2 degrees higher than room temp, the heat pump and strips come on.
When the room temp and stat temp are less than 2 degrees the strips turn off.
That is, unless the installer wired the t-stat for the strips to stay on.
If they are coming on in the air/cool mode then you have a bad heat relay or a t-stat wire shorted.
Mar 11, 2009 | Coleman Heating & Cooling
Problem with heat pump
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Aug 18, 2008 | Coleman Mach III Air Conditioner
My heat pump is pumping out warm are instead of cool. I have our thermostat set to 69, on cool, and it got up to 80 degrees before I finally turned if off and opened the windows. This is my first time...
its wired wrong the thermostst has wires running to the indor unit and the indor to the outdor wiring these units can be a bit complicated even for pros so use your judgement if you dont think you can handle it leave it to a pro be couse you can cause serious damage to your electronic board and that will surely cost you
May 25, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
