Question about Homelite Garden
Homelite timberman 45 fuel line replacement diagram
Fuel line routing diagram
SOURCE: fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: I have a Homelite timberman 45. It won't idle.
been out fighting 2 saws today,r+r lines filters one problem on 1 saw same went from 50/1 to 30/1 quit over heating and evaporating gas,, pulls easier fires an pulls chain well on big cuts//used 50on two cords cool day last year today 80+ over heated
Posted on Mar 21, 2009
  • 384 Answers
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
Posted on Jun 12, 2009
  • 61 Answers
SOURCE: Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
Posted on Jul 10, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel line diagram for 358.352160
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
How do the fuel lines rout on a homelite 45 including from tank, primer bubble to the carbeurator
Without the UT number from the saw won't be able to give more detail carburetor hookup. Here is a generalize fuel hook-up diagram.
Depending on the carburetor both of the fuel lines can be on one side only. The suction line connection for the primer is usually closest the the metering diaphragm.25331542-pzxv2dmyt02yqunciumgycfv-5-0.png
Dec 21, 2014 | Homelite Garden
I have a homelite timberman 45 that starts and runs fine,but at high rpm it bogs down, like it's starving for fuel, what could it be?
You may adjust the High adjustment screw on the carbarater most of the time carbarater needs to be rebuilt.
Nov 22, 2014 | Cars & Trucks
Diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Oct 22, 2012 | Homelite Garden
Can you email the page on how to tighten the chain on timberman 45 model...lost my manual. thks Dennis draralbee@msn;.com
This page will help. You may not find your exact model but just find one thats close
Good Luck and BE SAFE
Follow link below cut and paste in address bar
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Feb 07, 2011 | Homelite Garden
Old gas, will not start. homelite "timberman 45"
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 30, 2009 | Homelite Garden
Mar 21, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Fix bar brake on homelite timberman 45
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
502 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
