Question about Ultra Linear UL-2200D Car Audio Amplifier
Ultra linear ul2200d wrked previously took it out put it bck in turn the gain up and green light turns to red sound stops?
Green light stays on until the gain is turned up. then green light goes out red light turns on and the sound stops all connection are very good the amp will wrk with the gain turned all the way dwn as soon as you turn it up it goes out and red light comes on.
  • Jeff Mooney Feb 20, 2012
    the amp is hooked up to 1 12" pioneer shallow mount sub. 4ohm 250watts nominal 1000watt peak and the amp is bridged
3 Suggested Answers
  • 11 Answers
SOURCE: Ultra Linear UL600HC gain pot broken off of board
No, open the system, check the switch in questions, get a soldering iron and desolderer to remove the switch, do it carefully, when you have the switch in your hand go to maplins or somewhere like it, find an exact replacement(wont be hard to do) and get someone confident with a soldering iron to solder it back in.
Posted on Sep 02, 2009
SOURCE: lost gain remote for Ultra Linear ul600hc
I have like four of those extras
Posted on Feb 02, 2010
I plug my tv in the light stays green it turns red sometimes it turned on last night the light was red when it was off turns green when its on I plugged it in now won't turn on but the light is green
It sounds to be a panel fault. Contact any service technician, and make it sure. If you wish to get some screen-shots about faulty displays http://electronicshelponline.blogspot.com/ check this link. Pull up previous posts there, either by its left side bar, or view it in Timslide option.
Jul 01, 2013 | Televison & Video
Red light is on. It is not blinking, it is solid on. no paper jam, all doors are closed. I took the cartridges out went back and force with them, and put them back. Help !, the warrenty just expired last...
if there is no paper in the printer the red light will stay until you put some on it, make sure that when putting paper it goes all the way until the end and the red light will turn green, then you can print.
Mar 04, 2011 | Samsung CLP 315 Laser Printer
Light rolling from green to red
stephen I think you are in sleep or lock out mode. Try turning the power on and pressing the horn button twice see if it stops scrolling if it doesn't turn the power off then turn it on and immediately push the joystick forward until you hear a beep then immediately opush it to the rear until you hear another beep then release it to the center. If it is in lockout you should see it return to normal lights Hope this helps
Nov 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Will not turn on after charging
Sounds like it's time for new batteries.
Jul 18, 2009 | Jet 3 Ultra Power Chair
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Axim x3 power switch light flashes green constantly
as far as I remember its the wireless working, if you press the button on the far right u can disable the wireless..this will turn off the flashing green light.
May 30, 2008 | Dell Axim X3 Pocket PC
Soung prob
Tune the gain on your amplifier powering the sub. Turn the Bass Gain on the amp all the way down and crank up your system to as loud as you can stand. Adjust the bass Gain until the Speaker begins to distort, then back off a little bit. This way you can crank it up and not get Bass Distortion early.
Nov 28, 2007 | Ultra Linear UL-1600M Car Audio Amplifier
Ultra Linear UL-2200D Car Audio Amplifier Logo
49 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Professor_V
Professor_V
FastHarley
FastHarley
matthew nulph
Level 1 Expert
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
