Question about Canon PowerShot S60 Digital Camera
Poor image displayed on cscreen after shot taken
The display when the camera is first opened flashes black and white. When an image is taken the image is very gray almost looks overexposed but there are also horizontal white lines through the image displayed on the lcd screen. Almost looks like a poor fax print when cartridge low. Please help I need to photo some boats today Cheers (Yacht) Broker guy
  • Anonymous Mar 19, 2014
    after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
Posted on Nov 09, 2007
This is the full link on the posting above:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=10149&keycode=2112&id=29819
Posted on Dec 30, 2007
  • 188 Answers
Just try taking a picture in low light and by switching off the flashgun. if the image then produced is quite reasonable then you have a damaged flex ribbion cable carrying signal to the apparture system of the camera. once the flex is changed the problem will be solved.
Posted on Aug 25, 2006
My screen is black and will not display images to shoot. Also when picture is taken it plays back as black image. Previously taken pictures will display.
Michele, a stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 19, 2011 | Canon PowerShot SD960 IS Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
I dropped my camera and since then I can take photos, the camera focuses, my display is fine when viewing previously shot images and the normal display information but when the shutter is pressed all o see...
When you take off the lens and fire off a shot, does the mirror go up and return or does it stay up? If not, is it possible that it is staying up when the lens is connected? When you fire a shot, can you hear it returning?
Sep 19, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
My camera takes picture but there all black? The
Last year my Canon PSA60 got the black screen in shooting mode. Menu display was normal and so the picture review mode.
Canon service center replaced the image sensor for free. When it happened again, I asked the service center for unit exchange (trade-in/upgrade program). Now I have my PowerShot S5IS. Good bye PSA60.
Canon has issued this in their notice page: http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=notices-digitalcameras-lcd
Regards,
Herry Chris
Aug 11, 2009 | Canon PowerShot A60 Digital Camera
THERE IS NO DISPLAY EVEN IF THRE IS A FLASH
Its bad ccd imager problem in your DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
Jun 09, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Problem with display being white...but!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2008 | Canon PowerShot A60 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Canon PowerShot S60 Digital Camera Logo
281 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
