Question about Exercise & Fitness
My theradyne TM 940 treadmill displays Error 3 when I turn it on, what does this mean?
  • maria Mar 10, 2012
    try re setting it. Do you know who to contact with any problems? I lost my safety key and cant find replacement anywhere.
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: what does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Posted on Apr 04, 2013
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
What does an E3 error code mean on my vitesse endurance xt treadmill
Apr 03, 2013 | Exercise & Fitness
How do you get into the service menu of a precor 932i treadmill?
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have.
E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence.
Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker.
What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
Nov 07, 2012 | Precor 932i Treadmill
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    What means error 07 by HAMMER walkrunner? how can i resolve that?
    means 2 options:God bless you
    ERROR CODE # 7
    E7- 1) Alternative Elevation Motor
    1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
    2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
    3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
    4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
    2)Alternative:
    Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
    c) Cause: Line Cord Damaged Solution: Replace Line Cord
    d)Cause: Fuse Solution: Check Fuse on MCB
    Oct 08, 2012 | Hammer Walkrunner Rpe Treadmill
    Message in the display "err 2" and my kettler treadmill doesn't work
    Hi Rendra,
    Try this:
    Switch the treadmill off and then on again.
    Push the "minus" speed button and the "stop" button simultanuously.
    If all is well you will now have entered the maintenance mode.
    Next push the "plus" speed button and the "stop"button smultanuously.
    Now you you've reached the error mode.
    Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
    The push start to erase the message.
    Turn the power off and then on again to restart the treadmill.
    With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
    Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
    May 10, 2009 | Exercise & Fitness
    Exercise & Fitness Logo
    347 people viewed this question
    Top Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
