Question about Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite dryer smoke inside drum - Kenmore Elite HE3 Steam 8674 Dryer
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
codfish124
  • 36 Answers
SOURCE: Kenmore Elite He3 electrical dryer runs but it does not heat up
mots likely your heating element is out replace it and you should be good to go
Posted on Dec 12, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Posted on Oct 08, 2009
How to clean under the blades inside kenmore elite dryer?
You must remove the drum, to remove the drum vanes or baffles to clean under them. If these are the blades you are referring to.
Jul 19, 2014 | Kenmore Dryers
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Replacing dryer drum Kenmore Elite Electric Dryer
Usually from the front. Lift top and remove front. I can't image it would be worth replacing the drum. What is wrong with the drum? or do you mean the belt to drive the drum.
Jul 25, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Kenmore HE2 Dryer Blades Loose
Yes. Depends on your model. The top, front and rear come off of some. Very easy fix. Your screws should be on the floor under the dryer.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell
Kenmore Elite HE3 Steam 8674 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
