Question about RCA Televison & Video
My cable connector pulled out from the tv and now the tv won't stay on the power button will blank three times and go off what can be the problem?
  • 5 more comments
  • bryantg33 Oct 27, 2008
    i resoldered it and it still won't work does cable connections have any thing to do with the tv not staying on?
    i pluged the dvd to the tv but the tv will not work no picture no sound or anything.
    the connector was broken about how much will it cost to replace the tuner if that's the problem
    the tv brand is a RCA model;D52W26
    can i replace the circuit board myself ?
    i want to thank everyone for their help i want my tv fixed but i just don't have the money to put it in the repair shop right now. Thanks very much for the advices.
    thank you.
  • 728 Answers
You might have messed up the inside electronics and software on the circuit board in the tv when the cable was pulled from the back of the tv without being unscrewed. You might need a new tv but try to check a few things first. Look at the cable cord that got pulled from the back of the tv and see if there is anything else on it other than the screw that held the cable in the back of the tv. If it is a small piece connected to the screw, then you just might need the circuit board replaced in the back of the tv. Then try plugging up the tv and pressing the power button twice. If it doesn't stay on, then you might need a new circuit board.
Posted on Oct 27, 2008
  • Jazz Boyce
    Jazz Boyce Oct 27, 2008
    If you can not get a new tuner for the price you want, you might just have to get a cheap used one from the same type of tv you have.
  • Jazz Boyce
    You could. All you have to do is unscrew all of the screws from the tv and take the back off. Then you should see a circuit board near the place where the cable was pulled out. There should be screws holding the circuit board down. Unscrew those and if there is a cord connecting the circuit board to the tv, then disconnect the cord(s) and put in the new board. Put all of screws back in and test it. It should work.
    Brigadier General:
  • 6,966 Answers
Your post "cable connector pulled out" as the original issue. However the "tv won't stay on" is indicative that the protection circuitry has kicked in and the unit has sustained some sort of damaged sensed by the protection. Offhand, this could be cracked board, tuner block dislocation, cold solder or just about any other possible electronic defect. Initially, you would need to visually inspect for any of the aboive and thereafter proceed with voltage checks and circuit diagnosis. Pls be reminded of safety requirements when working with live units.
Hope that this be of initial help/idea. Pls post back the brand and model, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 27, 2008
    Hi again,
    Can you do it yourself, yes. Assuming you have familiarity with electronic components & circuitry, use of a DVM and a soldering iron. If you are considering a DIY, it would be to your advantage to have access to a service manual or at least a schematic diagram. It would seem that there is little free info on the D52W26 but you could start here. Additionally, you could order a service manual from here. The idea is not to start/work blind. The service manual would have a checklist that one can follow to arrive at a more conclusive diagnosis.
    Cheers.
    President:
  • 2,712 Answers
Some Tv's wont come on until it recievs a signal, like a cable signal or a DVD signal, etc. The cable connector is broken and will have to be fixed/replaced. Once that is done, the TV should work. You can verify by connecting a DVD/CD player to your TV and see if the TV works or not..
Posted on Oct 26, 2008
  • 905 Answers
When the cable got pulled it broke a connection on the board , and thatswhy it won't come on
it will need to be resoldered where the cable was pulled
need more help just ask me!
electech
  • 10 more comments
  • jason Oct 26, 2008
    if you move the tuner in back the tv might come back on if not then its broke and either they can replace the connector or the tuner its self will need replaced
    is the connector bent or broke?
  • jason Oct 27, 2008
    yes , without that tuner connected on the board( where it probably needs to be soldered) it will not complete the circut
    how bad was the connector dammaged?
    and if it cracked the tuner board then the tuner will need replacing , and i belive you can get a tuner for that very easy
    you have to make sure the tuner itself is soldered good and that it did not crack the tuner board or the main board
    they will vary depending on how you go about getting the tuner , but usually there not exspensive shouldn't be more than $100 ,check with some suppliers give them the tuner id number and get a price then check others to get the best price
    i'm looking for some good places and prices for you , be back with the best results
    here is a great place to get the parts
    http://www.teeveesupply.com/product_page...
    but i'm still looking for you for better prices
    can you upload a picture of the dammage so I can better determine the dammage?
    was the tuner ripped from the board? if not then its not that bad ! if the tuner is not soldered to the board well anymore the tv won't start up , is the tuner dammaged? or the main board that is soldered to?
    it may only need to be resoldered ! and that don't cost anything, and a new connector is only 1 dollar
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
I have a sony KV-30HS420 CRT HD television whose menu keeps flashing on and off. I'm not sitting on a remote anywhere, and I've disabled all the signals in the house that I think might be...
Hi
Get the set to reset fist and see whether it helps you. To reset it do the folloing:
1 Press POWER to turn on the TV
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
If this process does not solve the proble of your TV, its memory IC has damaged. Memory IC is one which holds the data we enter to the TV set, and the processed is stored. It is a nn volatile memory [the memory stored in it won't get lost even power is switeced OFF]; which holds all the data in. The data stored in it will retrive to main system processing IC each time we switch ON the TV set. This is an eight terminal IC, very samll one indeed, can be located very near to the main system control IC, at system control section. It can be repalced. This IC can be bought from most of the electronic spare part shops at your town. It is very cheap to buy. Even though it is very small and cheap one, its function in TV circuit is great. Almost all the functions data is stored in it each time we operate the system. It will have a specific number printed on it, and should be noted when buy a new one. Insist on that number, substitutions or an other number won't even switch ON your TV. OK.
Jul 15, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
RCA D56W20-No Power
NO you cannot. Call a good TV Tech and have him trouleshoot that circuit board and replace the RF connector.
Jul 29, 2009 | RCA D56W20 56" Rear Projection Television
Tv problem
the tuner will need to be replaced
Oct 26, 2008 | Televison & Video
42 inch Vizio will not stay on
There are 4 scenarios.The most afford part out of these scenarios starting at $215 to $850.
My recommendation:
A. use a repair tech.
B. Buy a new TV cause there are knock out deal right now at circuit city(chapter 11)!
solutiondoct
Sep 25, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
TV SHUTDOWN
hi there, there is a power supply section problem, do some test, automatic shutdown means a power supply section problem. ty
Jan 10, 2008 | Sanyo HT32744 32" TV
Televison & Video Logo
91 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
