Question about Kenmore Elite HE4 Electric Dryer
Dryer isn't working
When I push a dryer setting, the correct setting comes up, but when I push start it just beeps. Also, the light went out recently. Could they be related? It is a kenmore elite dryer h3 and it is about 7 years old.
  • 1 more comment
  • jsand22 Nov 02, 2008
    Ihad the exact same thing just happen to me, however, this occurred after a widespread power outage right after our power came back on. Could a surge when the power came back on shorted something?
  • lizzardhips Nov 07, 2008
    Yes, I am perplexed.  All lights are working, settings register correctly, yet when I push the start button a triple beep... but no reaction.  Anyone with suggestions... my dryer is only 2+ years old.
  • Hilblee Nov 21, 2008
    Select on front and lights work but when you hit start it just beeps. Unplugged and let it sit. Still nothing. I have noticed that the inside light doesnt come on when the door is open now. I cant see a blown bulb not making the dryer work though.
I had success.  I found the manual....unplugged the dryer, and rotated the inside drum several times to check for any coins or small objects.  I did not find anyything, but if something small was lodged it is not hampering the dryer.  I plugged it back in and it worked right away...
lizzardhips
Posted on Nov 09, 2008
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
New whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Mar 29, 2009 | Whirlpool WED9500T Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Whirlpool Electric Duet Sport Dryer
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Start /stop problems
check to make sure you have the belt routed the right way around the idler pulley.
Nov 11, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
Kenmore dryer
IF THE DRYER COMES ON BY ITSELF WHEN THE TIMER IS SET AND THE DOOR IS CLOSED, THE PUSH TO START SWITCH IS SHORTED. THIS WILL CAUSE THE END OF CYCLE SIGNAL TO BUZZ WHEN THE TIMER IS IN THE OFF POSITION(END OF CYCLE).UNPLUG THE DRYER, REMOVE THE BACK PANEL OF THE CONSOLE, AND REMOVE ONE WIRE FROM THE PUSH TO START SWITCH. ISOLATE IT SO IT ISN'T TOUCHING ANYTHING AND PLUG THE DRYER BACK IN. SET THE TIMER AND CLOSE THE DOOR. IF IT DOESN'T START UP OR BUZZ, UNPLUG THE DRYER AND REATTACH THE WIRE. PLUG THE DRYER BACK IN AND SEE IF IT STARTS BY ITSELF. IF IT DOES, THE PUSH TO START SWITCH IS SHORTED AND WILL NEED REPLACED.
Apr 01, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
192 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
