Question about Dell Inspiron One 19 (884116044949) 185 in PC Desktop
Inside dell inspiration reset button location
How to factory reset dell 1320c printer
Hi Rolando,
You can download the manual copy of Printer at http://downloads.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers_color_laser/dell-1320c_user%27s%20guide_en-us.pdf
I am copied information for you. Here is the information for reset of printer.
Using the Reset button
Your printer is supplied with an electric leakage detector, which prevents electric shock or fire due to electric leakage by automatically cutting circuits inside the
printer.
When electric leakage is detected, the
Reset
button is tripped. In this case, press the
Reset
button to turn the printer back on. If the
Reset
button is tripped
again after you press the
Reset
button, contact Dell.
Check whether or not the electric leakage detector is functioning at least once a month by following the steps below:
1.
Turn on the printer, and then press the
Test
button.
l
If the
Reset
button is tripped and the printer is turned off, the electric leakage detector functions
correctly. Press the
Reset
button to turn the
printer back on.
l
If the
Reset
button is not tripped, contact Dell. Do not continue to use the printer if the electric
leakage detector is not functioning.
Let me know if issue is fixed.
Regards
VIkram
Oct 09, 2017 | Dell Office Equipment & Supplies
Does the dell inspiration 7500 have usb ports
It looks like you will have to have a wireless card to connect to the internet, here is a link for you to look:
http://support.dell.com/support/edocs/systems/psyd/specs.htm
You should be able to explore there, hope this helps.......
Oct 17, 2012 | Dell Inspiron 7000/7500
Can I reset my phone
yes 1. Power the phone off.
2. Press and hold Volume Down and Power.
3. Keep holding both buttons until you see the Android logos appear on the screen.
4. Use the Volume Down button to toggle the selection and highlight Factory Reset.
5. Use the Power button to choose Factory Reset.
The HTC Inspire 4G will then complete the hard reset process. SD card data like music and photos should be preserved.
Software method
If you can boot into the device, you can use this option.
1. Tap the application slider and select the Settings app.
2. Select SD & phone storage.
3. Choose Factory data reset.
4. Select Reset phone.
5. Select Erase everything.
Oct 12, 2012 | HTC Inspire 4G Smartphone
I have an htc inspire and the touchscreen stopped working/ is frozen, how do I get it to respond or will I have to replace the touchscreen?
Please follow the following procedure to hard reset ( factory reset ) the phone . If that does not help Please take it to a authorized service center .
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Downfor NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 10, 2011 | HTC Inspire 4G Smartphone
How do i do a hard reset on my htc inspire
  1. Power off the device.
  2. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options.
  3. Press the Volume Down button to scroll down till you highlight "Factory Reset".
  4. Press the Power button to restore your phone to factory settings and also your phone will restart.
Aug 01, 2011 | HTC Inspire 4G Smartphone
How to hard restore this phone.
Hard reset on HTC Inspire using the phone buttons:
1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If your can not turn HTC Inspire 4G on, you should choose the latter way to reset your device.
Jun 18, 2011 | HTC Inspire 4G Smartphone
I dont know where my wireless button is on my dell inspiration 5100
the function key and F2 (Fn+F2) enables and disables the wifi
Dec 26, 2010 | Dell Inspiron 5100 Notebook
Dell inspiron 1521 cd key
u can get cd key on www.torrentreactor.net
by writing " key for dell inspiration 1521 "
or on google
write "key for dell inspiration 1521 for windows or vista"
or ucan go on www.freekey.com
Mar 04, 2009 | Dell Inspiron 1521-JB Notebook
Dell Inspiron One 19 (884116044949) 185 in PC Desktop Logo
Alun Cox
