Question about Roper RAS6233KQ Top Load Washer
Washer won't start/fill/spin -- anything
I have a Roper RAS833PQ that is only about 18 months only. It won't do anything. It just died. It was working fine and then nothing. I have checked the power source and the fuse box. There is power going to the washer. I've seen some things about a "lid switch," but I'm not sure how to check that. Please help!
  • Deanna Mies Aug 24, 2006
    The machine doesn't do anything. It just sits there. I have lifted and lowered the lid and it does click. I tried to use each temperature setting and cycle, but it does nothing. There is no water coming in. No spinning. Nothing. It is absolutely dead.
    If it doesn't do anything at all, can the timer or lid switch (if those are the problems) be replaced inexpensively without having to call in a repair person? Or do I just have a giant paper weight sitting in my basement?
  • connor6180558
    connor6180558 Feb 08, 2014
    With the lid down, hold down the Start button until you hear a click. The washer should begin to fill.
    President:
  • 878 Answers
Dea, does the washer fill? If it fills and justs sits there it could be the pressure switch. If it fills, agitates and then no spin no drain, then it's the lid switch. If it doesn't do any of the above, it may be a timer issue. Lift the lid and gently lower it, do you hear a click when the actuator on the lid hits the switch? I will attempt to attach a picture on how the consol flips up to see the lid switch harness, pressure switch and timer. Your model will have two screws that must be removed, they maybe in back of the end caps. To remove the lid switch unclip the clips on the right and left side, unplug the harness and tip the cabinet foward. You will see how the lid switch mounts to the cab. Catriver..post back
Posted on Aug 24, 2006
  • Ron Marek
    Ron Marek Aug 24, 2006
    Dea, if you have power at the outlet and the machine doesn't do anything it's more than likley your timer. Even if the lid switch was bad the washer would fill. There are some tests you could do buy you would have to have a meter. For the model number of ras6233kq0 the part number for the timer is 3953146. The price is around 68.30 for the timer. With-out being there and doing some voltage checks, and what you are describing I would believe it's the timer. It's an easy job. But try unpluging the harness to the timer and reseating it first. Catriver...post back.
SOURCE:
Keep burning out control modules on a 92 prelude si h23
the alternator is a fuse /fusible link check to see if that is ok or anything also your heat sencor is probbaley on its way out
Jan 28, 2014 | Honda Prelude Cars & Trucks
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
I have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 13, 2011 | Roper RAS8445KQ Top Load Washer
The refrigerator on our Roper side by side refrigerator/freezer has frozen everything from veggies to milk. Any clue as to what the problem might be? Greg Russell
Your thermostat has probably got its contacts withing fried together and it is not shutting down.
Obviously the compressor and fans are working fine. It has to be in your control. Your ice box has a mercury based control. The temp is controled by it and nothing else. It can fail by burnt out contact. (open) OR Fried together contacts (stuck together won't shut down). OR Loss of mercury in the probe.OR kinked probe.
Aug 14, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
NOT WORKING AT ALL
If youv'e still got the receipt ...get the serial # off the machine and give Royal a call at 1-800-524-0799 and see how they can help.
Jan 20, 2010 | Royal Office Equipment & Supplies
Roper RAS6233KQ Top Load Washer Logo
3,908 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
