Question about Home
I need the installation instructions for Kander MF 157 2 in one shower
2 in one shower system, on a rail. Shower head with hand held and built in diverter
5 Suggested Answers
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 81 Answers
SOURCE: Can this diverter run both
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Posted on Oct 24, 2010
canwoodjc
  • 3301 Answers
SOURCE: I have installed a new
ok, first , and people always forget to do this,, remove the shower ( hand held part ) head, when turning off the water , and then back on, all kinds of gunk travels through the pipes , with the head off check the pressure,, if it seems ok, the head itself is clogged
Posted on Aug 25, 2011
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
I have a Ace Oak Brook hand held shower head white #4195962 and I need a new hose, is it possible to get a new one? The part that screws into to shower broke.
Ace hardware can get that part for you. Your local ace my have it in stock. The part is not available anywhere else.
A genaric replacement my work but I would go with the ace brand.
Feb 01, 2011 | Ace Hardware OakBrook Hand Held Shower...
Can this diverter run both the shower head and a hand held shower.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
I'd like to install 1 shower had and one hand held shower. What do I need to have ?
well you can do a 3 way shower valve , or a mixing valve with 2 control valves. or you can do just to regular shower valves one for each of the heads you want one for the rain and one for the shower head. this way is cheeper and you can have one on hot water and the other cold water or the other way around or both the same temp.
Apr 26, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Water trickles out of hand help head
the problem is probably not in the actual head but in the valve body where the diverter is attached. It is easy to google something like "how to change the washers on a faucet" and you will find step-by-step instructions on how to do so.
http://www.dummies.com/how-to/content/how-to-replace-a-washer-in-leaky-faucet.html
May 16, 2009 | Delta Faucet Delta 75582 In2ition 2-in-1...
Bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Oct 16, 2008 | Home
Home Logo
18 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
