Question about Ovens
Ilve fan forced oven - fan screeching
The fan screeches when turned on, after a few minutes the high pitched noise stops. A replacement is $130. Anything to try before I order one?
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
  • 93 Answers
SOURCE: fan screeching on my gas oven, if it packs in can
You cannot use the oven on fan forced- buy a new fan motor
Posted on Aug 29, 2009
  • 87 Answers
SOURCE: My whirlpool Accutone double oven
bad bearing.
Posted on Oct 14, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Hi there, I've got a
Sorry to read about your problem, I hope this helps you out.
sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Ilve oven fan
Either needs cleaning or replacement
Dec 19, 2015 | Ovens
Oven "screeching " noise .
Yes it wil continue to work on manual basis
Oct 18, 2017 | Neff B1432 Single circotherm plus Electric...
Hi in there...high pitched grating whirring noise when i turn my oven on on any setting
It's probably coming from the fan in the oven.
It may be that an obstruction is hitting the fan blades or the bearings are gone.
Check visually to see if there is anything obvious but if not it will probably need a new fan.
Feb 07, 2010 | Stoves Ovens
Fan screeching on my gas oven, if it packs in can i still use the cooker ?
Aug 28, 2009 | Ovens
Ovens Logo
201 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
