Question about HP PSC 1610 All-In-One InkJet Printer
Paper jam always.
Last week, everytime the printing was "triggered" there was a funny sound like a machine gun rat-tat-tat-ting for about 12 seconds then it would print. Now, that sound is gone but each time I try to print, the paper is jammed. Maybe the sound had to do with the rollers or something that controlled the paper feed? I can't print anymore. It always goes into jam mode and everytime, I clear out the tray, put in a new sheet, then it jams again.
  • 103 Answers
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Posted on Jun 16, 2017
  • 2961 Answers
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
  • 2785 Answers
SOURCE: Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
Posted on May 31, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
  • 106 Answers
SOURCE: Photo Paper Feed
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
Posted on Jul 07, 2008
Hp deskjet ink advantage 2515 paper jam error
Check it again, maybe a ting piece of paper is triggering the jam error.
Oct 12, 2016 | HP Deskjet Ink Advantage 2515 All-in-One
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Paper Jam/Cartridge can't move
Hello Julie how are you? Regarding on your problem try to remove your cartridge then installed it properly. Or try to open the back of you printer and try to see if their is a small piece of paper left during a paper jam incedent you have.
Jun 16, 2009 | HP Officejet 5610v All-In-One InkJet...
Loud clicking noice during copying
take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Feb 14, 2009 | Sharp AL 1631 Copier
Starting problems
get alternator tested loosen pinch bolt on battery tray 13mm
Jan 11, 2009 | Alera Technologies Cruiser (270118)...
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Paper not feeding
If there is no paper jammed inside the machine, then look at the "paper out" roller, this is the last roller in the paper path. I would suspect it is out of alignment.
May 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Paper Jam Error when no paper jam
well it could be, but normally the material is always right, therefore it could happen to be really paper jamed that u can´t see.
Sep 26, 2006 | Olympus D-555 Zoom Digital Camera
HP PSC 1610 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
