Question about GE Cooktops
Removal of GE Cooktop RU38C
I need to remove my 27 year old Cooktop to measure the drop space and install a new GE Cooktop
4 Suggested Answers
SOURCE: Electronic ignition clicking on cooktop
one of the burner switches has shorted, and needs replacement. Turn the power off to cooktop, and check with VOM if there is any continuity on any of the switches when the y are in the "off" position. Replace the one which has continuity. Some GE cooktops have an assembly of all four switches and harness. Check by model number with any parts distributor.
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: I just spilled water onto my gas cooktop and now
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
  • 185 Answers
SOURCE: removed old 110 volt 2
Are you sure you got the right burners. Sounds like they gave you a 220 volt burner with one wire red and the other black.
Posted on Feb 12, 2011
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Tip
    How to fix GE cooktop error code F116
    First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
    ApplianceZone.com Items
    1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
    Sub-Total: $170.67
    Shipping: $6.95 Standard Shipping (6.95) USD
    ApplianceZone.com Total: $177.62
    Once i received then new burner i just replaced it and all is working fine, no error code!
    First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
    on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
    GE Profile cooktop JP360. Trying to remove cooktop to install new granite countertops. Also have GE built in oven JTP 15 below. Called G.E. Customer Service today and was told to just pry the top off...
    Hi marilynmcdon,
    You can do it yourself. These cook tops are not glued to the granite at all (Or is not supposed to be). Simply lift is up slowly, start from the side, and lift it slowly. If done carefully you won't damage anything.
    Hope this helps
    JEDEMEYER1
    * If this solution helped you, please rate it.
    Aug 09, 2011 | GE 30 in. Profile JP350 Electric Cooktop
    How to replace a cooktop drip pan
    It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
    Benjamin
    Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
    GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
    Turn off the gas,unplug the power.
    Take the cooktop out of the cutout and support it on the countertop.
    Remove all grates and valve knobs.
    Remove all screws from the valves and the burners.
    Remove the burner base plates.
    You may have screw on the side holding the top to the base,if so,remove these too.
    The top will separate from the bottom exposing your parts.
    Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
    GE gas cooktop
    Wow, never heard of that,.... bleeding through glass? I checked the GE service web site and there are no Service Bulletins relating to anything like this. I guess if it were mine and I had that history with it, I'd try the new top, but removing the gasket and first putting a layer of foil duct tape on the underside of the new glass top, then use some new foam gasket material under the cooktop. Good luck. Please don't bother to rate this solution, as anything but a fixya will lower my rating. Thanks.
    Nov 08, 2008 | Cooktops
    Coils don't heat
    The control knb are being worn need to replace it the terminals are rusty conductance may not flow./not heating the coil.
    Dec 24, 2007 | Jenn-Air Expressions AC110 Electric...
    Installation of new electric cooktop
    If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
    Apr 22, 2007 | Whirlpool 30 in. RC8700 Electric Cooktop
    Cooktops Logo
    160 people viewed this question
    Top GE Cooktops Experts
    Dan Webster
    Dan Webster
    Dave Harrison
    Are you a GE Cooktop Expert? Answer questions, earn points and help others
