Question about Proscan PSVR83 VCR
No eject My Proscan PSVR83 VCR will not eject the tape that is loaded. I've taken the top cover off but don't see a way to manually turn the loader motor shaft in order to manually eject the tape. I would greatly appreciate your help. Do I have to start with taking the front panel off in order to take the bottom cover off? Do I need to remove it in order to access the loader motor shaft in order to turn it by hand? It sounds like there is a drive belt on the loader motor and, if so, I need to replace it. How do I access it? Thank you very much. Don Johnson daj3245@msn.com Tallahassee, Florida
2 Suggested Answers
SOURCE: My vcr lcd reads LOCK now and I can't access any menu functions
My Proscan PSVR74 turns on, says "Hello" and immediately goes to Stop and turns itself off. Is there any hope for this machine?
Joe
Posted on Jan 03, 2008
dodgecharger
  • 254 Answers
SOURCE: All of a sudden no picture just snow
Do you have a spare TV? Hook it up to the Sat. box. If you still have no picture, then the Sat. system has a problem. If the sub TV does have a picture, then the problem is on the ProScan end.
Posted on May 09, 2008
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
VCR tape stuck in machine
This could be a loading basket issue, or the tape has become tangled in the machine. Unplug the vcr, remove the top cover, if you see tape spewed in the mechanical section, plug the power and turn on, now try eject! if you see the tape pulling disconnect power and cut the tape with scissors and remove all the bits and pieces carefully not to damage the video head. If luck is with us the machine hopefully will eject the main cassette. If the tape is not the problem it is a loading issue, probably will need a technician.
Jan 17, 2011 | RCA DRC8335
Tape in. will not play or rewind - can't eject. screen reads 'LOCK'
open the vcr look on the right side you will see a belt attached to a motor use your hand and manually turn the belt until the tape ejects
Jan 03, 2010 | Proscan PSVR83 VCR
The 'take up reel' does not turn. Tape starts doubling up on the capstan which requires taking the cover off to get the tape to eject. Craig
You may need to look at the bottom of the unit and see if a belt drives is broke or came off.
A/V Media Tech Guy
Nov 23, 2009 | Proscan PSVR83 VCR
Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Jan 29, 2009 | Panasonic AG-7350 VHS/S-VHS playback VCR
May 06, 2008 | Proscan PSVR83 VCR
Joe
May 08, 2007 | Proscan PSVR73 VHS VCR
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
