Question about Samsung Digimax S500 Digital Camera
Battery? I just purchased the camera last night. Installed the included batteries, took a few pictures. When I put the camera into auto macro mode, set the resolution to super fine and try taking a picture, the camera shuts off and will not come back on. The lens is still extended from the camera. The same thing happend last night, without the super fine resolution. I took out the batteries and put them back in and the camera functioned normally. But today it will not come back on. All told, I have taken less than 10 pictures. Could the batteries be dead already?
I just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Posted on Oct 23, 2006
SOURCE:
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
Turns on and won't turn off has a picture of a battery and a flower
Try to push the ON/OFF button longer or harder. If the problem persist, take the batteries off then put in again into your camera.
Picture of battery shows your battery stats full/empty.
Picture of flower is indicator that you use "MACRO" mode, this is mode when you have to take a small picture with near range between object and lens while capturing the picture, not suggested for taking daily pictures. If you don't need this function you can turn off the "MACRO" mode, certain camera have dedicated button to adjust it, but see the manual to make sure.
Hope this help and be kind to rate please, thank you.
(^_^)
Jan 06, 2011 | Cameras
How can i use the macro in my sony dsc-w120 .there's a shortcut in using macro in my cam but everytime i click it it says that macro is invalid..what will i do?i want to capture pictures using macro.please...
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
Dec 30, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
Dec 10, 2009 | Kodak EasyShare Z612 Digital Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Rosita
Make sure you didn't accidentally put it in macro mode. The macro mode is selected by pushing the little "flower" button on the selector buttons near the right side of the camera. Press that button and make sure it is set to "off". Also make sure the battery door is closing all of the way. If necessary. duct-tape the battery door shut.
Aug 26, 2008 | Olympus FE-100 Digital Camera
Lost Pictures
I'd recommend that you follow this digital camera photo recovery guide as soon as possible to recover those pictures.
Mar 25, 2008 | Nikon Coolpix 4600 Digital Camera
Preview Picture - Locked Up
Eventually, the camera's battery will die. I suggest removing the battery and then wait for 30 seconds and put it back in. This should solve the problem.
Feb 29, 2008 | Kodak EasyShare DX6490 Digital Camera
Samsung Digimax S500 Digital Camera Logo
75 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
