Question about Leviton COMBINATION SINGLE POLE TOGGLE SWITCH
Single pole switch and receptable installation
Ibought the above .It is for under my bar.I need a switch for a small light, and a receptable for my phone charger. There are two wires from input. had a single switch that worked the light fine.Now I want a receptable to plug in my phone charger. I know its not rocket science, and I am a do it yourselfer (I hope !!) The man at Home depot tried to explain it, but by the time I got home,and hooked it up , only the light would go on and off. No juice to the plug. Hope you can supply with with a simple hook up diagram, or any suggestion would be greatly appreciated. Thanks.
    Genius:
  • 1,605 Answers
You may already found the answer to you question.
but anyway, here it is.
split the black wire (hot), one to the light (not the light switch), one to the outlet (copper screw).connect a white wire from the outlet (alium screw) to the copper screw on the switch.
connect a white wire from the alium screw tothe white wire on the light.
Posted on Nov 07, 2008
  • Frank
    Frank Nov 07, 2008
    sorry that was a worng wiring.
    split the black wire (hot), one to the copper screw on the switch, one to the outlet (copper screw)
    connect a black wire from one side of the light to the alium screw on the switch.
    connect a wite wire from the other lag of the light to white wire on the outlet alium screw.
Why after installing a Pass and Seymour lighted single pole toggle switch, the CFLs in my bedroom light flicker on and off.
Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 06, 2014 | Electrical Supplies
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
I"m installing a Cooper Devices
Wiring is suspect.
Black hot wire connects to dark screws.
Break off tab should be intact.
White neutral wire connects to silver screw.
Wire going to switch load connects to brass screw.
Jun 18, 2011 | Cooper Industries Cooper Wiring 274W...
HOW DO I CONNECT TO POWER SUPPLY? WHERE DO THE WIRES GO?
You posted under Intermatic EI210 countdown timer.
To confirm this is your product, open link below:
http://www.amazon.com/Intermatic-EI210-Electronic-Countdown-Minutes/dp/B001EE1J74
Manual with operation instructions appear on link below
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei220w%20-%20english.ashx
EI210 replaces single-pole switch only.
Single pole switch is where 1 switch controls the Load (light, fan, motor)
To wire this timer:
1) Single-pole switch has 2 insulated wires and 1 bare ground wire.
2) Connect insulated switch wires to timer red wire and timer black wire, in either order for now.
3) Connect timer green wire to bare ground wire.
4) In back of electric box are white wire that are twisted together and covered with wire nut. Connect timer white wire to these wires. This will power electronics located inside the timer.
5) If electric box does not have white wires described above, then connect timer white wire to bare ground wire along with green wire.
6) Turn power ON. Press oval button. If indicator light turns ON, then timer is wired correctly. If indicator light does not come on, then reverse timer black wire and timer red wire.
http://waterheatertimer.org/How-to-put-on-wire-nut.html
Add a comment if you need more free help.
Also take advantage of fixya phone service.
For a price, fixya expert gives you same instructions shown above via phone while you connect the device.
Dec 30, 2010 | Intermatic EI210 Electronic Auto Shutoff...
Installing a combination switch
The three way will have more connections, whereas the Single Pole, should only have a few contacts the three way will have more.
May 27, 2010 | Leviton 002-1754-W Dual Rocker Switches
Pushomatic Double Pole, 20amp problem. When I
Most two-pole breakers have a small plastic bar that connects the two switches allowing them to be synchronized and used as a single breaker. However there are some two pole breakers that are intended to be used as two separate breaker and lack the need for the bar that synchronizes them, this is because they are not being used to power a single circuit or item, but separate circuits, or items. so no the breaker is not bad, and yes can be used to power single circuits or items.
Jan 17, 2010 | Connecticut Electric & Switch Thqp115...
I have a live 2-wire line that used to be connected to a light with a switch built into the light fixture. I removed the fixture and put wire nuts on the live wire. What I'm trying to do is to wire the 2...
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Oct 17, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Hooking up a combination switch with outlet and another switch
ok, i think what you mean is a 3-way switch- meaning two different switches that control one light and a single (pole) switch that only controls one light. you can't do that with the above switch. You need a combination 3-way and single pole switch.
Sep 30, 2009 | Leviton COMBINATION SINGLE POLE TOGGLE...
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Leviton COMBINATION SINGLE POLE TOGGLE SWITCH Logo
297 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
