Question about RCA D56W20 56" Rear Projection Television
Convergence board not found
I have a rca d56w20byx2 and my convergence board i belive is shot. but when i pull it apart it looks like i have three diffrent boards. which one should i start with and just make sure i work on the right one what would it look like and where can i buy a new one
  • Willie Howell May 11, 2010
    You have concergence issues's is the picture bowed and 3d effected. there are three boards that effect covergence. so determine which one it is will need to toubleshoot a little further. so first question. what does your picture look like bowed 3 d does autoconvergence work. do you have the convergence option. in manual convergence does the crosshair move up and down side to side
  • RCA Master
  • 5,138 Answers
First go to menu then setup look for convergence on menu if it is not there you have a OPEN fuse FL231 it will be on right side of FBT flyback transformer there is 3 of them in a roll small brown rectangle it will be the Middle Fuse.
Posted on Feb 19, 2009
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue, red and green lines running across the top of the screen. Picture looks like 3d. No convergence on the menu.
This is self protection on the set. Near the high voltage transformer inside the set (it is located as you look from the back on the far left and will either be black or tan--it has a large red wire coming out of the top of it) next to it are 3 tan colored coils--they look like resistors--one of them is gone----this is why convergence does not show in the menu.
One of two things wrong here---either the part just failed or THERE IS A SHORT IN THE CONVERGENCE circuit--it is spread across the circuit boards---these sets are prone to this and you will find many shops do not want to work on them.
Boards are no longer available from RCA except on a rebuild basis.
All parts are RCA only---the coils may be found at a number of sites but that board has to come out.
The coils can be tested like a fuse (which is what they are).
I have seen other techs in the shop I work for spend hours trying to get one of these sets up again.
If this told you something you did not know, rate my solution here as very helpful as I do this here for free.
lF any questions make a comment here.
REGARDS, SD TECH
Aug 18, 2010 | RCA R52WM24 52" HDTV Projection Television
My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still...
unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Jun 16, 2009 | RCA Televison & Video
My colors are out of alignment, I can actually see three different ones they are about an inch apart on the screen and there are 3 color lines draped across the top. I get a high pitched squeal, it has had...
Convergence. very common. First question when you go into the customer menu under setup do you have the convergence option. If you do not suspect the convergence fl231 fuse problem. i hove wrote instructions under the tips and trick section. The bowed picture and line definatley indicates a loss of convergence power. There are three seprate cuircit boards that controls this convegence power, convergence amplifer and the small signal board.. the small signal board would have to be replaced by tech. as there is special equipment requird. the other two you can do. If you have convergence option try the autoconvergence option and watch to see what it does
Nov 18, 2008 | RCA HD52W59 HDTV Projection Television
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence...
since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Jun 24, 2008 | RCA Televison & Video
Rca p56926 convergence problem
kraze3,
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Nov 23, 2007 | RCA P52926 52" Rear Projection Television
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power board...one color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59YX35
just found the problem fuse that causes this to happen. The set I have also was not converging, and the auto convergences option was also gone. The small fuse labeled fl231 which is right next to the big plastic piece with the large red wire coming from it in the left corner of the circuit board closest to the back. It is the middle of the 3 small fuses that are smaller than a Chiclets gum. I was able to pull up the circuit board and jump the fuse with some alligator clips and the set looked great again. Every one says watch out for the unit with that red wire SO WATCH OUT!
damortch check out mouser.com I think I found them on there gonna call them tomorrow to see if I can get mine there.
Oct 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA D56W20 56" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
