Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Incorrect Tv colours
My tv displays so many unwanted colors such as, red, green, blue, yellow, and they created a circle pattern. Then the screen goes of its position(it becomes a trapezium) HELP!!!!!!!!
  • pcgenevitz Dec 05, 2008
    I have cable service and when my tv is on for abit, my color will begin to have a rainbow effect across the entire screen. This continues when I bring up the cable prompt or change the channel. It's been fixing itself lately, but I forsee this as being the beginnings of a major problem. Furthermore, if the rainbow effect continues on the set, it will lose color all together and you'll get a fairly standard black/white picture. The set is a whopping 4yrs old and it's making me miss the Zenith I replaced it with that lasted 21yrs prior to the Sony..
    Genius:
  • 1,139 Answers
Hello Roloi,
This sounds like a problem with your yoke transformer. I would suggest having a qualified TV technician work on this problem, because it involves testing a component that could have dangerous current in it.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 25, 2008
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
The color from our RTD258RV dvd player is green and yellow. Can anything be done or do we need to get a new unit??/
From your description, it sounds like the RED connection is not being made.
The colors are created using RED, GREEN, and BLUE (RGB) primary colors to create other colors. If any one of the connections is not made, the colors will be incorrect.
Check to make sure the RED connection is good, with no damage or breaks in the cable. If it appears to be good, it still may be worth replacing the cable, which is much cheaper than a new TV!
Jul 15, 2011 | Audio Players & Recorders
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
JVC Model AV-48P575 Green/Yellow Screen
i would check the red color first it sounds like your loosing red
Feb 22, 2008 | JVC AV-48P575 48" Rear Projection...
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
