Question about Nokia X7 Smartphone
Nokia x-7 won't turn on and stay on
My zeepad won't boot up
I'm having the same problem I've tried everything and nothing's working please help
Feb 20, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
So I changed the oil in my friend car and she has really high mileage on it so I put 10W-30 in it for high mileage an now it won't start can you help me out please
I would suggest a full synthetic oil, next time & stay with 5W-30
That will be better on start up
I have no idea why it won't start after only changing the oil
I think that was just a coincidence
I just installed a new throttle body ,because the motor has
acted up for 7 months & unknown the battery was failing
as I was diagnosing some odd behaveour
I was using professional scan tool software & when that
went weird I saw the computer module & battery voltages
going down,key on,engine off. So strange things happen
with todays electronics. When your think your on your game
things go to the twylight zone
May 23, 2012 | 1997 Chevrolet Lumina
My Nokia 6790 won't turn on, what's wrong with it?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jun 20, 2017 | Nokia 6790 Surge Cell Phone
Nokia 6205 got wet & it won't turn on i would like to remove contacts
Please remove batteries and use a blow drier on low setting to remove moisture from phone. ( Please do not heat battery)
Dec 22, 2011 | Cell Phones
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Nokia X7 Smartphone Logo
362 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
