Question about Brother SE-270D Computerized Sewing Machine
My Brother SE-270D Disney Sewing and Embroidery Machine is acting up...mostly when I try to bind a blanket together...it acts like it is going to work...then 10 stitches later (not literally) it starts to make these atrocious sounds and then an error comes up saying that the safety whatever has been activated, and the back of the fabric is a comeplete mess. I have tried TONS of things to get this to stop, but it seems to want to keep messing up...please help
  • Brother Master
  • 7,365 Answers
The machine needs to be serviced so you can find out about the unusual sounds
Posted on Feb 21, 2012
  • Rachel Flock Feb 28, 2012
    Idk how to get it serviced, it was a gift from my grandma....? are there places for that? or do you have to send it off somewhere?
  • the place where your grandma bought the machine, if it's still under warrenty.
    if it's not under warrenty then a sewing machine shop that does repairs
  • 29 Answers
SOURCE: Instrucitnos for Brother SE-270D Timing Problem
This is not really something you can do yourself (been there, tried that!). The machine has to be almost completely disassembled to get to the timing mechanism. Trust me, it's worth the 30.00 to have it timed.
I think http://www.allbrands.com has a generic timing explaination for sewing machines (use the drop in bobbin one)...I found it easy to follow...but once I realized I had to unplug all the components for the computerized functions... I took it in to the dealer. If you contact Brother & your machine is under warranty, they will pay for the repair (they paid for my first two re-timings). Now I know you HAVE to use BOBBIN thread that is 60 WT only in the bobbin. You will continue to have problems if you don't. Also, this machine uses the class 15 bobbin, but make sure its model number SA156A, which is a hair taller than the SA156 bobbin..both are class 15, but the tiny difference is very important.
Posted on Aug 12, 2008
  • 21 Answers
SOURCE: DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Posted on Sep 21, 2008
SOURCE: Thread tangles under throat plate while embroidering
Take the cover off or at least enough to blow the gear drives out around the area of the thread cutter. We use a air pump that you use to blow up an air mattress with. You will also need tweezers to pick out the thread etc. that gets wrapped around the gear and in the teeth. What happens is the gear drive gets clogged and does not turn freely.
Mary
Posted on Jul 26, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 32 Answers
SOURCE: brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Posted on Feb 05, 2010
How do you change the light bulb on the Disney 270D embroidery machinr
The Brother 270D uses an LED light. Part number XC3503021. The assembly costs about $25. I do not believe this is a user installable part.
Apr 01, 2014 | Brother SE-270D Computerized Sewing...
I have a Brother Se 270D sewing/embroidery machine. It makes a terrible grinding sound and won't go all the way up or down. I have removed the thread, bobbin, and bobbin case and cleaned all of...
Take it in for service, hopefully it is still under warranty, I have sneaking suspician that your motor is causing the problem. I had a machine that did that and it turned out to be the motor.
Apr 20, 2011 | Brother SE-270D Computerized Sewing...
Hi,i have a disney sewing and embroidery amchine.It won't loop th it was threads together.Local repair man said it was o/ut of time.CAN YOU HELP/
If the timing is off is needs an authorized repairman to fix it with metric tools. Not a repair that can be done at home. Usually costs between $50-150 depending on your area.
Aug 14, 2010 | Brother SE-270D Computerized Sewing...
Its missing plastic flap in front of machine
You can order one from Ron at a1sewingmachine.com. Look in your manual to give him the correct terminology.
Dec 16, 2009 | Brother SE-270D Computerized Sewing...
I have a Disney Brother SE-27OD Embroidery Sewing Machine When I am doing the embroidery the needle comes out I put it in as tight as possible but it keeps happening from time to time.
Make sure you have the flat part of the needle to the back when putting it in and that it's (preferably) a Schmetz embroidery needle with the red band either 75 or 90 or a Schmetz universal 80. Make sure when you install it you can see the top of the needle in the needle slot and all the way up so it's hitting the post before you turn the screw tight. Check the screw each time you sew to make sure it hasn't shaken loose from embroidering.
Dec 13, 2009 | Brother SE-270D Computerized Sewing...
Stitching loose. won't thread the fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
I need a replacement needle to embroidery. need to know the model#. I have a Brother SE-270D Easy Thread Cassette System.
The thread cassette has no bearing on what needle you use. You need a Schmetz embroidery needle with the red band size 75 for light to medium weight fabrics or a size 90 for heavier fabrics such as denim.
Dec 07, 2009 | Brother SE-270D Computerized Sewing...
Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Jul 22, 2009 | Brother SE-270D Computerized Sewing...
Embroidery machine patterns are not consistant
I'm just beginning to work with my machine, but I have had a similar issue. Some of the possible solutions that I have found include (note: I've tried #1, I will try 2 and 3 soon)...
1. use stabilizer fabric.
2. if you're using tear-away stabilizer, and it is tearing prematurely, try a cut-away stabilizer (or maybe iron-on stabilizer?).
3. if you're embroidering on fabric like fleece, try 'hoopless embroidery' This involves using adhesive stabilizer - put the stabilizer in the hoop with no fabric, (if you don't have adhesive stabilizer, use regular stabilizer and spray it with a craft adehesive) then lay your fabric over the hoop and press the fabric onto the adhesive.
good luck.
Dec 17, 2008 | Brother SE-270D Computerized Sewing...
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
156 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
