Question about Nintendo The Legend of Zelda: Phantom Hourglass for DS
How do I equip spirits? - Nintendo The Legend of Zelda: Phantom Hourglass for DS
Tip
What to do when a phone falls into water and stops working. Equipments Needed:...
Equipments Needed:
Local/foreign booster
Chemical (spirit/thinner)
Blower/Dryer
Sand paper/Eraser
Digital meter
Procedures to follow:
Step 1: Remove the battery and boost to 3.7 volts
Step 2: Disassemble the phone and wash with spirit/thinner and heat with a blower/hair dryer and assemble the phone to power.
Step 3: If no power, use sand paper and eraser to clean all the connectors and interface for a better connection.
Step 4: If no power still, replace the battery with a new one.
Step 5: Use a digital meter to read the power interface or the power switch to see if there is power on the board.
Step 6: If no power still, do heating with hair dryer again.
Step 7: Finally you can power it up with the use of software.
on Jan 19, 2010 | Cell Phones
Tip
How to check and correct a bad Mouth Piece Equipments Needed Digital and Analog...
Equipments Needed
Digital and Analog Meter
Chemical (Spirit & Thinner)
Procedures to follow.
Step 1: Check and read the mouth piece to see if it's good
Step 2: Check if the terminal is connected on the board interface.
Step 3: If it's not connected, clean and connect it.
Step 4: Read the interface on the board to see if it's reading continually, if it isn't, loop for macro phone sound.
Step 5: If the situation still remain the same, check if the mouth piece is bad and if it is, replace it with a new mouth piece and make a call to make sure someone hears you.
Step 6: If it is still not working after following the above steps, then you service the board interface by washing it with spirit/thinner and heating it with a blower.
Step 7: You can also check to see if the phone is not lapping and you advice the owner to buy a new case for the phone.
on Jan 11, 2010 | Cell Phones
Console magnet
Hello. I may not have an exact solution for your problem but I hope I can point you in a direction that may be helpful to you. You can view a list of Spirit equipment at this link. If you cannot identify your equipment from this list then what you will want to do is click the "Contact Us" link at the bottom of the page to see if they can research the manufacturer for you and identify the exact part that you need.
Aug 21, 2013 | Spirit Esprit ET4 Treadmill
How do i replace a hose on the power steering
As replacement hoses are expensive, my approach (here in Mexico) was to go to an industrial hose outlet, and order them save the connections and replace the hose section. They crimped the new assembly and it was good again. As steering is critical, and handles high pressure, a good shop is necessary. But industrial hose oulets have the proper hose (and some even better than the original) and the proper crimping equipment.
Mar 28, 2012 | 1991 Dodge Spirit
I have a Spirit home gym that is hoked up wrong. Looking for schematics for this particular piece of equipment.
Hey!
Here's a link for a list of manuals. Dunno specifically which one you have. Try to check if you have the model that is available in the link.
Hope this helps! :D
Sep 09, 2010 | Exercise & Fitness
The plastic bushings in the weight plates of my Spirit Freedom Series 1 are loose and need to be replaced. Where can I get replacments?
You may have to call spirit direct to to find out if they even have these bushing. Call them @ 1-800-258-8511
One Other place I found a plastic bushing is at www.fit-senior.com
| Fitness Equipment Replacement Spare Parts | Weight Stack, Weight Stack Keys and Weight Stack Plates | Weight Stack Plates & Bushings
Jun 12, 2010 | Exercise & Fitness
Equipments
To be a successful mobile phone repairer, you have to learn how to repair mobile phone with softwares and hardware.
Hardware requires the use of equipments which include
Allen keys/ screw drivers
Picker
Digital/analog meters
Local and foreign booster
Enlargement lens
Chemicals (thinner and spirit)
Foreign and local rework station
Soldering iron and led
Paste
Flux
Tinny copper
Eraser
Razor blade
Sand paper
Go and get this equipments, and i will teach you how to use them.....
GOODLUCK
Jan 08, 2010 | Cell Phones
1992 Dodge Spirit ignition cylinder problem
I have a 93 and had the same problem. It is your 'Lock Cylinder'. To replace it, you will have to take off the steering wheel. if you have an airbag equipped spirit, remove that first after disconnecting the battery and waiting 15+ minutes. on the right side there will be a spring loaded mechanism you need to push down th a small tool. make sure your keys are ut and its in the off position. the cylinder should pop right out. get a new lock cylinder at an auto parts store. price varies, from 15 to 80 bux. beware and test the new mechnaism a lot if you can before you pop the new cylinder in. I put a new one in and it got stuck on run. it is a nightmare to take out when in run. The new one pops in with the spring loaded mechanism fitting into the hole. wiggle the steering wheel if it doesnt set all the way down at first. Replace steering wheel and airbag. test from drivers side.
Jul 29, 2009 | 1991 Dodge Spirit
Fan belt
the fan is electric and does not have a fan belt.
Nov 14, 2008 | 1994 Dodge Spirit
Nintendo The Legend of Zelda: Phantom Hourglass for DS Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
