Question about Whirlpool CSP2761 Gas Commercial Dryer
Whirlpool CSP2761 Gas Commercial Dryer wont turn off - timer problem?
I bought three new stacked Whirlpool CSP2761 Gas Commercial Dryers. Three of the six dryers work fine except they won't shut off. The supplier said to run them for a while as sometimes they come from the factory with time accumulated on the timer. I ran them for a total of 18 hrs each - no luck! A Whirlpool serviceman told me the accumulator/timer probably isn't good and needs replacing - please verify. PS; the timing wheel and the crash (part that activates the timer when you push the token slide in) are properly in place.
  • dewittdonny Jan 28, 2009
    I have the same problem.If I change the timing cam should this be able to solve my problem?
  • 1028 Answers
SOURCE: Whirlpool commercial gas dryer
replace push to start switch
Posted on Aug 30, 2008
onthejob5130
  • 640 Answers
SOURCE: timer is humming but drying not turning on
defective timer,,onthejob
Posted on Feb 02, 2009
mark_37388
  • 100 Answers
SOURCE: new whirlpool dryer duet steam wont work
Sound like the unit doen't know the door is closed the door switch is not working. does the light inside the drum come on when the door is open and off when the door is closed
Posted on Mar 30, 2009
woobie dog
  • 1273 Answers
SOURCE: Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Posted on Jul 28, 2009
milten1
  • 1304 Answers
SOURCE: Whirlpool lgr4634eq3 gas dryer-runs on low heat or
i would check your gas valve coils
they are probably weaking or at least your hold is
but i would replace both
they sit right on top of your gas regulator behind the ignitor
two littly tube like things
Posted on Oct 09, 2009
Drying time taking to long
Try putting a vaccume cleaner as far down the vent hose as it will go and suck anythng in there out, , And if you can put a vacume cleaner attachment in the lint trap and suk some stuff out as well ,, other than that i doubth that there is anything else that can cause the problem...
Jan 16, 2008 | Whirlpool CSP2761 Gas Commercial Dryer
DDE7000SBLWW GE Dryer not turning off
you have a bad timer,if it sticks in the same spot and you have to manually turn it to off i would say you have a bad timer.part number WE4X831 and it's around 120 dollars.i would buy a new dryer,get a whirlpool dryer instead of putting money into the g.e.
Nov 12, 2013 | Kenmore 60172 Electric Commercial Dryer
Dryer wont stay hot
Assuming you have removed the lower access panel (two or three scres all the way at the bottom of the lower front panel) to view the glow plug (ignitor), if you see the ignitor cycle on but the gas does not ignite after the machine initially heated in the beginning of the cycle you will want to replace your gas valve coils. They are the round black things mounted to the top of your gas valve.
This should solve your problem.
Good luck to you!!
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
My Maytag Dryer Wont Heat, Im an amateur repairman
Inside the dryer on the bottom right corner.
Mar 10, 2009 | Maytag MDG6657BW Gas Dryer
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool CSP2761 Gas Commercial Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
